Remove the wire that triggers the relay power from the hot side feed of the high beams and put it to a hot switched power source such as an ignition side fuse location or to a always hot source or like mine is off the parking light feed.
Some states require it to be wired so they only work while the high beams are on.
It's an easy fix
