That's funny, I dont care who you are
x2 This was driver error causing him to high center. The FJ would have done the same if driven the same.High center is high center no matter what vehicle your driving. Also the idiot driving has more to do with it.
H3 has only 1/2" less ground clearance than the FJ. I would venture to say that with the same driver he would have got an stock FJ stuck there too.
I'll bet 95% or more of H2s and H3s have never been offroad.
It's a given that if he had approached at an angle he probably would have never had a problem.High center is high center no matter what vehicle your driving. Also the idiot driving has more to do with it.
There is a 2.4 degree difference in breakover angles, to the FJ's advantage.It's a given that if he had approached at an angle he probably would have never had a problem.
I have gone straight over bumps and crests that are much more severe than what I see in that video. And, I have high centered on some and just scraped off of them. He probably got one wheel light, spun it, and it was all over. Active traction control (not to mention RR locker, and locking transfer case) would have cured that. Also, ground clearance is only one factor. What is the break-over angle on the H3? I would guess it is less than the FJ.
He probably posed for the video. The H3 isn't even running. I bet they drove off.He probably got one wheel light, spun it, and it was all over. Active traction control (not to mention RR locker, and locking transfer case) would have cured that. Also, ground clearance is only one factor. What is the break-over angle on the H3? I would guess it is less than the FJ.
I have to disagree with the FJC portion of that, unless you're strictly talking 2WD FJCs.Same could be said about FJ, Z71, Range Rover...
On edit: My FJ hasn't been off-road....yet. LOL
