1 - 10 of 10 Posts
Just a note to say that despite reading of the problems member FJC650 posted 04/08/2019 "Fed Up With Falken Wildeak AT3Ws" I decided to try them based on all the info I could gather- though his post did give me pause, for real. However, for the money, and for an all around "All Terrain" plus 3 peak Snow Rated Tire, I had to go for it. Bought through Amazon Prime at $142 each- free delivery. So Far they have not let me down. I'll come back with an actual review after I put on more miles and have driven in snow and more of a variety of road experiences.
Before going on the Highway the first time (week and half after installed), checked the tire pressure and one back left was 10 Lbs over- like 45 PSI (they should be in the 33-35 range, - in upper end when "hot") according to what I have read and been told. I had all five new tires- including the spare changed over, plus the Automatic Tire Pressure Gauges (ATP) put back on. The tire Guy that installed the new tires had reset my ATP Warning light (which was "on" before new tires). One Mystery: The ATP Warning light did not come on when the second Tire Guy let out the extra 10 pounds...will have to follow up on that. No telling WHY my warning light did not come on- it should have IMHO. To be continued...
Did find out one thing I want to pass along- DO NOT tighten the tire valve stem caps too much as it can cause failure/damage to the stem! The first thing I did was tighten the caps, and the 2nd Tire Guy noticed it, and told me why the First Guy had left them kinda loose.
After the previous discussion (in FJC650's post) about "stacking Sticky Weights" I made sure to check the weights I could see and also note how the FJ was driving at different speeds. I noticed about 5-8 weights (the most I think was 8) per tire- see photo. Assuming these are the "sticky weights"? Is this an unusually high number of weights or are the A/T tires just harder to balance. I could see where they scraped off 8 previous weights, so assuming this is relatively normal. The weights say 5FE ( 5 Grams Iron/ roughly 30 Grams/Ounce).
With the Falcon Wilpeak AT3W's my FJ Feels more "solid" on the road, with a slight vibration around 60MPH that goes away at 65. Steering is straight and steering wheel not jittery at 65 MPH. So I am assuming the First Tire Guy (installer) balanced the tires well, despite his helper over inflating one tire. Always check your tire pressures and anything else if someone else has been working on your FJ. Noise- probably slightly more noise, but FJ's are loud anyway. So I am very Happy with the new Tires!
I have a 2013 I've had for 5 years, with 32,000 miles, and it had the original Bridgestone Dueler H/T's. The original tires were 6 years old, and absolutely reaching the point of needing to be replaced. OK for highway but scary in heavy rain with standing water. We live in the VA Mountains so it is great to find an affordable All Terrain, year 'round tire which is Snow Rated, and which I can go on back roads with. I like the design of the tread, and the extra rubber on the sidewalls I hope will help when I do drive on some of the rougher Country Roads. Not planning on doing any heavy duty Off Roading, or Mudding, so these should be fine.
Hopefully I can get these photos to work! And figure out WHY my TPM Alarm light didn't come on when he let out 10 Lbs of tire pressure....(yes they did put the TPM's back on I checked). :wink
MODerator**Kindly Change my Title to 265/70R17/115T thanks!
Falken Wildpeak AT3W:
Five Weights-one wt fatter?:
Spare:
Side View:
I have them on my 2016 F150 Fx4 and after 5,000 miles really like them. I have not had them in winter time yet but they should be very good.
I used them Ouray CO air down and they did fantastic on 5 days of off road. Did Imogene, Engineer, Ophir and many other passes with them. I highly recommend!
I do prefer a little more aggressive for the FJ have 295-70-17 Nitto's they were on when I purchased it.
I`m on my second set already and will get another set when these are done. I have 285/75/16. Love these a lot :)
BTW Discount Tire did have a very competitive price (same). I just like to use my Amazon Prime when I can, since I pay for it.
Thanks for the feedback..
AH
Vendor
AH,
Thank you for your comments. We can appreciate you wanting to use the services you pay for, keep in mind Discount Tire and Discount Tire Direct always guarantee the lowest price on all the products they carry. We would love to have the opportunity to earn your business next time.
Glad to hear you are liking the Wildpeak A/T3W tires so far.
BTW I mentioned that one of my tires was overinflated about 10 pounds and I was worried because my TPMS light should have come on when tire pressure was released to 35 PSI. However, I thought about it, and actually I believe the TPMS light won't come on until you go below the normal tire pressure and down to somewhere around 23/22 PSI. I'll still have to test this out near an air hose to make sure though that everything is working correctly.
I literally just bought 4 of LT versions of the same Wildpeak at Walmart for $140 each. Have not picked them up yet. I looked far and wide for good tires that wouldn’t break the bank and these seemed a good choice. I hope they work well.
I know this thread is a little old, but I figured positive reviews could help anyone considering these tires after seeing the negative experiences others have had with the wildpeaks.
My wildpeaks are 255/80/17 E range
We finally got some snow and I spent the majority of the day driving around playing in the snow. My results are going to be a little different from others because I have pizza cutters and that surely helps cutting through the snow and getting traction. Most of the snow I encountered was no more than 7" deep and unfortunately most roads being only a couple inches (darn climate change). They handled great in the hard packed snow. They held up on ice decently for not being snow tires. They performed well enough that I would take them up in the mountains and not worry about whatever deep snow I came across.
I haven't had a chance to take them in mud, but they ride well on rough dirt roads and don't hydroplane on the road.
Being 10ply they sure are heavy, but the skinny tire makes up for it. Unfortunately I didn't balance the tires myself and the tire shop that did mount the tires didn't bother taking the old weights off and managed to destroy the plasti dip on my wheels with the duck head. So I can't say for sure how well they balance. As of now the FJ is my daily and they ride great on road. They aren't loud compared to other tires and they have a great looking sidewall.
In case you still are still on the fence I know a couple guys that have them on their trucks and an explorer and they've had no issues.
Summary
Being that these did so well in the snow I have my doubts how they will perform in the mud. If I weren't running a different tire and size in the summer I would consider these for year rounders. I came from cooper AT3s in the stock 265 size which were also good in deep snow. I would recommend these tires to anyone who encounters snow and wants a quiet all around good tire. If you rotate every 5k you will get your moneys worth out of them.
Hopefully no one cared too much about me turning the icey church parking lot into a tire proving grounds.
1 - 10 of 10 Posts
