1 - 4 of 4 Posts
Hello,
I have ordered Icon Tabular UCA kit part # 58450 which I thought its the right UCA for FJ Cruiser. However, when I checked on Icon's website, I've found out that the advertised UCA for FJ part# is 58451.
I checked the installation guide and found out that there is only whan item which is different between the two kits which is the Tapper Adapter.
Tacoma: (2) 157518 TAPER ADAPTER
FJ Cruiser: (2) 157517 TAPER ADAPTER
I have sent an inquiry to Icon to clarify if the one I ordered can fit the FJ, but wanted to check if anyone here can advise.
Thanks in advance!
Mohammad
Sent from my SM-N960F using Tapatalk
Discussion Starter #2
Just an update in case someone faces the same issue.
Its confirmed that the only difference between the two UCA kits is the Tapper Pin. According to Icon Vehicle Dynamics, the Taper Pin is different to handle better alignment for various vehicle.
With other UCA brands, you may find the kit is similar for Tacona and FJ!
Thanks,
Mohammad
No worries.
The recommendation from Icon was to make sure that I install the right dapper pin. So I had two return the kit to the store and exchange it with the right one.
However, Icon customer service told me that if I order this directly from them they would accept exchanging the dapper pin only.
So I haven't seen the Tacoma's dapper pin to answer your question.
Thanks,
Mohammad
1 - 4 of 4 Posts
