1 - 20 of 28 Posts
Well my driver side tie rod is shot so its time to replace both sides. Found some aftermarket outer rods however, I cant find the inners. Some threads here mentioned the release of Moog inner tie rods. Anyone know if thats a reality? Or an affordable alternative?
Tie Rods & Components - Auto Parts Warehouse
I just ordered a set of the moogs, these are the best alternative to oem, i ordered them from rockauto and got them in a day shipping. Will be installing them this week.
Did you get a set of these? Also do you think they would screw into the outer rods without problems?
$71 seems a little steep for these, especially since the others are around $30. Any way you can snap a pic?
RockAuto Parts Catalog
here is a pic of em, one cool thing was they're black compared to the stock silver inner tie rod ends.
they may be a little pricey, but not as much as OEM inner tie rod ends, and I've had many fj people tell me moog parts are good quality parts and they are made in korea. I wouldn't want to spend 30 bucks on a cheaper made inner tie rod end only to have it fail on the trail and have no steering. With these, I also ordered the Deeza outer tie rod ends which are cool because they have greasable zerks!
Are these as simple as just screw them in? I assume you need to make some length adjustment relative to the outer end?
I paid to have the eom installed last spring, totally got screwed $160 each plus the install total bill was like $550.
I'd like to install these myself next time.
I've just put in Napa brand inners. As you can see the shaft is actually stronger "looking" then stock. Doesn't taper as early as stock.
I would suggest you do both inner and outer at the same time.
Forgot to mention its made in Japan. Part# 269-3301.
Discussion Starter · #13 ·
I went by Napa the other day and the guy said they didnt carry inner tie rods for the FJ. Interesting.
DoWork, it may have been listed under 4R. It's on my FJ now and it's working great!
You should use a specialty tool to install the inners, however it can be done with a pipe wrench in a pinch. Whatever you do make sure you use a lot of lock tite on the inner tie rod (WHERE THEY THREAD INTO THE RACK). Lastly you will have to have an alignment done.
What are you guys at mileage wise? I'm curious why so many of you need tie rods and what may be causing the wear.
I'm near 60,000 miles. The affected side is the side that I had hit a boulder in Sedona. The other side still looks pretty good. Frankly, I probably didn't need to change out both sides, but it wasn't that much more and it's good peace of mind.
Outters
Discussion Starter · #20 ·
the 4R would make sense. Ill swing by the store with the part number tomorrow. What outers are you running?
1 - 20 of 28 Posts
