1 - 3 of 3 Posts
Over the weekend I installed the Daystar 2 1/2” Leveling Kit. So far I've only installed the fronts. Currently all fender flairs are at 36". This week I'm going to install the rear, which will probably give it a little rake. I rather have a little rack, so when I am trailering the sleds the rear won't be sagging.
The kit was pretty easy to install.
There were a couple of things I did that were not in the instructions.
Unbolt the stabilizer bar from the frame; otherwise you can’t get the strut out. Keep on hitting the side of the upper ball joint until it release; it will after about 50 hits with a hammer and make sure you leave the nut on so it doesn’t explode in your face.
I couldn't get the lower control arm low enough to get the strut with the extender back in, so I wrapped a ratchet strap around the bottom of the strut and then across to the other side’s lower control arm. I slowly ratcheted until it popped into the cradle and lined up the holes for the bolt.
Oh and don't forget to use the Loctite that I found after I installed the first strut. I think it will be fine w/o the Loctite
I think it makes the FJ look 100% better and it rides pretty much the same as stock.
I will add more pics after I install the rears
Before:
After front kit was installed.
Installed the rear spacers.
Fender hight before and after installation of both front and rear spacers
Before front 33 3/4"
After front 36 1/2"
Before rear 36 1/2"
After rear 38"
Bottom of license plate
Before 22"
After 25"
1 - 3 of 3 Posts
