1 - 11 of 11 Posts
Sockless Superstar
Nice :)
I chose to permanently mount mine in the driver side panel as opposed to the windshield. I removed the panel, then I just used the back of the vent mount as a template, and drilled four holes in the panel and mounted it with the same screws :)
i have the strattus, its all i listen to #15 classic rewind
I got the Sirius set up through Toyota. It wasn't cheap, but it plays through the factory radio and uses the controls on the steering wheel. Had it done before my Sedona trip. Well worth it.
Regards, SSC
I'd love to get this setup, but I have to chose between gas and the Sirius. What good is a radio in a truck with an empty tank? :D
Very nice setup! You will LOVE it!
Is the aux input a replacement for the fm modulator? Where did you tap for the continuos power for the satellite holster?
To the OP,
Just a small thing i noticed, you can add a-trac to your vehicle by just buying the 40-50$ button. It is already on it since you have the locker and 4x4. I'd say it is easily worth 50 bucks to add it.
1 - 11 of 11 Posts
