1 - 14 of 14 Posts
After reviewing a multitude of awning types, styles, sizes and price ranges, I selected the ARB 2.5M X 2.5M. I wanted an awning that would essentially shade the entire side of the vehicle, utilized high quality materials, and has been in production long enough to uncover any inherent design or construction defects.
I have a Maggiolina Extreme hard-shell RTT mounted on an aluminum Prinsu roof rack, and the existing crossmember mounting slots in the in the rack side plates provided perfect attach points for my home-made aluminum awning mounting brackets.
ARB offers welded-steel brackets for their awnings, but they are expensive, can rust, and according to ARB are "not intended for off-road use", so I fabricated my own brackets out of 6000-series aluminum extrusions. All hardware is stainless steel, secured with Nylok nuts. ARB recommends that three mounting brackets be used with the 2.5M awning, but the slots in the Prinsu rack made it very easy to provide four equally-spaced mounting points.
The brackets position the awning close to the rack side plates, and at the perfect height. Slotted fastener holes in the brackets allow for fine adjustment of height and lateral position. 5/16-18 fasteners attach the brackets to each other and to the roof rack; ARB-supplied M6 stainless T-slot bolts attach the awning frame to the brackets.
The latest versions of ARB's awnings include a clear plastic sleeve on the underside for ARB's dimmable, bi-color (white/yellow) LED light-strip.This provides nice, even illumination under the awning.
In the end, this more than met my expectations for a clean-looking, low-profile, corrosion-resistant mounting system.
1120535
1120536
1120537
1120538
1120539
Looks great. Where did you purchase the awning?
One of Amazon's "warehouse deals", latest model in unopened factory packaging (huge heavy wall cardboard tube). Because of an error in the product description, an additional "adjustment" was made to the pricing that brought it down to $230, delivered.
An absolute steal at that price.
Yes, the awning had to go on the passenger side because of a ham radio antenna tuner that's on driver's side. Therefore, I had to fab an extension for the RTT crank to compensate for the added width of the awning.
I made an aluminum extension first as a model, with the intent of making a stainless part later. But the aluminum part is plenty strong and much lighter than stainless, so I think I'll just stop "improving" it.
1122508
1122509
Very nice, Well done!
Discussion Starter #12
Actually, I only bought the two siderails from Prinsu (back when rights to the rack design were owned by Prinsu Design Studios), and bought the 80/20 crossbars from a local 80/20 distributor. All the stainless hardware was also purchased locally.
I don't know what type of hardware is provided if you purchase the entire RR "kit" from Prinsu or CBI Offroad, but it probably isn't stainless.
(Just saw that Prinsu is offering a 10% discount March 2-8.)
A-Team Moderator
Their kit shows all black hardware.
Discussion Starter #14 (Edited)
I have 80/20 grab handles mounted at several places along the rack side rails to provide handholds while standing on the sliders and reaching up to open the RTT latches.
I didn't happen to have exactly the right length stainless bolts to attach the handles, and initially used black-oxide finished carbon-steel bolts but they quickly started rusting, even in relatively dry So Cal weather.
Of course, the Prinsu hardware might have a black epoxy or black zinc finish, or something other than standard industrial black oxide.
1 - 14 of 14 Posts
