Attached I found this PDF (pg 2), probably good idea that I found it. From reading the document, can you guys assist with the bolts I will be needing to torgue to spec?
These are the bolts, that I think I will be torquing and working with:
*Front shock absorber with coil spring x Frame assembly- 47 ftlbs
*Front shock absorber x Front lower suspension arm- 100 ftlbs
*Front lower ball joint attachment x Front lower suspension arm- 103 ftlbs
*Rear shock absorber x Rear axle housing assembly- 72 ftlbs
*Rear shock absorber x Frame assembly- 18 ftlbs
If I'm missing or need to change/add something, please advise.
Thank you
Thank you
