1 - 2 of 2 Posts
I have an 07 with normal wear on the steering wheel horn thingies.
Is there a way to remove these panels without removing the steering wheel?
If you've repainted anything in the interior with silver paint, what did you use for a match? Just left Home Depot and didn't find a match.
Thanks!
2007 FJ Cruiser
I wish I could tell you I found a match… Unfortunately no. I painted mine a hammered silver\black color. I ended up pulling the airbag and the two outer plastic pieces behind it. Just so I could do all my painting outside of the vehicle . I will say that it made painting them a whole lot easier as far as masking and overspray goes. Not sure how much that helps, but here’s my two cents. Good luck.
1 - 2 of 2 Posts
