21 - 34 of 34 Posts
Discussion Starter #21
Here is a close up of the fuse mount on the battery hold-down. I am posting this as a reminder to the others who got the dual battery kits, to install a fuse near to the aux battery so you don't have a catastrophic battery event when Murphy shorts out your wiring.
[/url][/IMG]
[/url][/IMG]
[/url][/IMG]
Discussion Starter #22
Finished up this project by routing the 2 Battery Tender cables on the batteries to the grill, where I left enough slack to allow them to loop thru and tuck back in behind the bumper lights. Now I don't need to lift the hood to connect/disconnect the Tenders.
And I did the seat switch that sounds a truck horn under the dash, with super bright 10mm LED on the dash when activated. Very cool security feature that I used to damage the hearing of my unsuspecting victims. Probably make a crook run off, unless the crook just tows the FJ.
OK, that's it, "DEMONS BEGONE!!" no more mods for a while.
Except there was an idea floated on the forum about adding a light to the suicide door...
Try spraying some spray-on tint on it. The same stuff people use to smoke out their headlights and turn signals.
Insanity? Yes, I have evidence.
Just got a Stinger voltage monitor and have mounted it to the left side silver plastic vent cover thing, along with a DPDT switch. I was going to use a momentary switch until I found that the Stinger has a "trigger" line, so it can be connected to a circuit that is only hot when the ignition is on (or aux). The switch is on-off-on, so left will be to see primary battery voltage, right for aux battery and center off, because the bugger looks like it might be too bright at night. Planning to install it tomorrow after getting rid of this pesky beer. :cheers:
Hey just an update to the questions asked above about the old style rocker switch. DP now makes one that fits in the stock switch blanks of the FJ.
Dirty Parts
Wish I had seen this before installing mine...
Discussion Starter #25
Dirty Parts
Cool switch, but what about the 'charm' of a Soviet style switch? :lol:
Hey, that new one looks like it has just 2 modes while the old style is a 3 position switch, Dual On, Dual Off and Emergency. Maybe the new one has a center position too?
Discussion Starter #26
Good idea, think I'll take it a step further and paint the top part of the lens with black paint. This gauge hasn't actually been useful in any important way, but it is a fun thing to play with. :bigthumb:
Discussion Starter #27
[/url][/IMG]
I just read a post about removing the diffusers inside the side mirror marker lights to improve the light output. Well, it does make them brighter. To remove them you just pop the mirrors off, remove the light and reach in there with a very sharp pick, I used one with a 1/2" right angled tip, and pull the stupid plastic disk out. I pierced it and pulled until it broke, then reached in with needle nose pliers to twist the buggers on their way out. The markers are very close in brightness and color to the parking lights now, a worthwhile 20 minutes and a good excuse to pop the top on a cold one. :bigthumb::cheers:
This is the pic before removing the disks, the after shot you can get by driving South on the same road that I am driving North on.:wave:
G'day Dougla2,
Sorry for my ignorance, can you explain why I should add a fuse in line on my dual batteries. I thought my Blue Sea 7622 ACR took care of the need for another fuse ?
I understand the isolation / fuse as a concept. But doesn't the solenoid prevent the idiot factor ?
Thanks in advance for the advice..
Tks Baz
Discussion Starter #29
G'day Dougla2,
Tks Baz
Hi Baz,
I needed a fuse for my situation because there is a heavy wire running away from the secondary battery, headed to the rear of the vehicle. If that line got mashed, like during a wreck or anything that shorted the line to ground, there is nothing to stop the battery from catastophic failure, so I put a fuse right at the battery. I do not know what happens if an AGM type battery gets shorted, but with an old style, you risk overheating and popping that plastic box full of acid. Unsure what to do in your case, but if it were me, I'd fuse the circuit right at the battery. Does Murphy's Law apply equally there in Oz? :cheers:
Hi Baz,
G'day dougla2,
Thanks for the message. Yes Murphy's law equally applies down under.. lol
Good advice too, how big should it be ? I am guessing huge..ish, would a circuit breaker work as well ? hmmm, I have a couple of 80 amp inline fuses spare and an 80 amp circuit breaker spare, but I think I should use some thing bigger... 200 amps or something ?
Thanks for the guidance.... much appreciated.
Cheers
Baz
Discussion Starter #31
G'day dougla2,
Cheers
Baz
To calculate the main fuse value, I just add up the loads and tack on another 10% or so, and consider the gauge and length of the directly connected wires. Be sure not to exceed the wire capacity since the point of having the fuse is to prevent the wire from melting down and starting a fire or, like mentioned earlier, destroying the battery itself. I'm sure someone will find fault with my off the cuff calculations, and I am open to learning a better way. I added up the fuse values of my accessories and came up with around 100A, and since my wire to the rear is an 8ga, chose a 100A fuse. This exceeds the rating for 8ga wire a bit, but I think the fuse would open before the wire could burn thru its insulation and certainly before the battery fails. And when everything is on, the total load is below 100A. Now, when I add the winch, it will be directly connected to the aux battery and have its own fuse. I do carry extra fuses of each type, which is a step up from the old days when I wrapped a blown motorcycle fuse in the foil from a pack of smokes to get home.:smoker::cheers:
G'day Dougla2,
OK, thanks, so the primary cable from battery to battery thru the ACR has a continuos rating of like 500 amps, peak 2500 amps... so I need a 500 amp fuse ? on B&S 2 gauge battery wire. WOW....
Then off the Aux battery I am running house electrics, again thru B&S 2 gauge wire to another 500 amp solenoid,less than 20 inches from the battery - then splitting out on 6 gauge wire to 4 separate 80 amp fused distribution boxes, and the ARB compressor @ 50 amp max load, total potential load if all are switched on about 370 amps. Each load is separately controlled via 80 amp circuit breakers then thru 100 amp relays from inside the cabin. Being able to switch each on or off as I choose.
So the house electronics are governed. I just need a whopper of a fuse for the primary cable..... and the cable to the 2nd solenoid another 400 amp fuse .... lol.
Does that make sense ?
I know my system is over kill, lol.... but i like to be safe.....
Thanks n cheers
Baz
Discussion Starter #33
:rocker:Way to go Baz!:rocker:
Now that is one over the top electrical system.:bigthumb: Instead of adding any sort of a fuse, I would suggest a great big fire extinguisher and maybe one of these.:jester:
[/url][/IMG]
Discussion Starter #34
It finally happened, the original stock Panasonic battery died. It only lasted 10 years and 11 months. It happened at the worst time, I was just leaving a medical treatment and was pretty wobbly. Fortunately, I have a spare battery on board, so put the "Soviet era switch" into the emergency position, hit the key and it started right up. Thank you to Dirty Parts for the kit, it worked perfectly. After the engine started I put the switch back in the left Dual On position and drove home to seek out a replacement battery. Probably go with a Diehard AGM, the local Sears has a Gold model. Happy. BTW, I still love the truck.
21 - 34 of 34 Posts
