How 100% positive are we that an H3 with the V8 is 5500 and the FJ is only 4400? I'm not...and I don't go off door jamb numbers either. The only way I've found accurate is to actually take the vehicle to a truck scale and weigh it.5500.. wow. a 5500lb fj would be easily out performed by a 4400lb fj with similar clearance, driving, and tires. Off road (in most situations) and on road. More likely to break suspension parts as well. like cv joints. I know other off road gurus around here think the FJ is overweight.
Heres an excerpt from a fine thread created by Sean K.
You can argue with him if you still don't think weight affects off road performance much.
http://www.fjcruiserforums.com/foru...35564-how-build-trail-rig-imo.html#post600585
Not sure about this one but, with an off road package or something you get longer shocks in the rear, and I believe that would allow one side of the axle to drop more. But an FJC with some sort of off road package should have been used for this comparison. They may have used an off road/tt/trd FJC but hey should have specified it. Inaccurate reporting.
Higher center of gravity means your more likely to roll over.
An FJ is not a 4runner. When I was doing research I came across many many people who had 285/75r16s and no rubbing. Some times there is a little rubbing on the part of the mud guard that covers the body mount. Thats easily remedied with a bit of trimming to the mud guard or taking it off. Someone also fit 255/85r16 bfg MTs, 33.3s, without rubbing.
http://www.fjcruiserforums.com/foru...55-85r16-s-mounted-trd-wheels.html#post153601
Ya I wasn't 100% serious about the H3 being an inferior piece of engineering. The FJC just has too many advantages over the H3.
Sadly many FJs and H3s are kept in captivity and forced to live a life of mall crawling, when the owner should have bought a van or station wagon or something.
My old Hilux Toyota was door jamb'd at 3600 lbs (IIRC) and it actually weighed about 4200.
Sean
