1 - 6 of 6 Posts
I'm gong to be purchasing a set of Kelly Safari TSR's in 285/70/17 and want to see if anyone had any luck having these fit with stock height. The tires are barely used and the shop is offering to mount and balance them for free...I plan on installing 5100 adjustable after I get the tires.
There are many opinions and results on the matter of that size tire fitting. I installed that size on a stock setup with no issues but it was close to rubbing the mudflap. The worst issue you'll have if any will be removing the mudflap or trimming the body mount.
Thanks Fjrohrs,
Mudflaps have been off for a while, but body mount might be an issue especially because of the Demello 3 hoop on the front. Makes me feel a little better that someones fit ok though!
No the deal fell through but i ended up getting Hankook Dynapro ATM
285/70-17's and they fit with no lift. There is a slight rub at full lock on the driver side tire but nothing major.
1 - 6 of 6 Posts
