1 - 20 of 64 Posts
Kiwi Cruiser
Here's my build/mods - still a work in progress, but this will help me keep track
SUSPENSION AND TIRES
ProComp Series 7005-7883 17x8 Flat Black Alloy Wheels
Gorilla Black Chrome 12mmx1.5 Spline Drive E/T Ultra Style Conical Lug Nuts
Toyo 285/75R17 Open Country M/T tires
ICON Extended Travel Remote Reservoir Front Coilover Shock Kit
ICON Tubular Upper Control Arms with Uniball Cover Caps
Mstudt Sliding Front Sway Bar Links
Wheeler’s Front SuperBump Bumpstops with 1/4" spacers
ICON 2.5 Remote Reservoir Rear Long Travel Shocks
Metal Tech 4x4 Heavy Duty Long Travel Coil Springs
Metal Tech 4x4 3" Bump Stop Extensions
Timbren Rear Active Off-Road Bumpstops
Stainless Steel Extended Brake Lines
Metal Tech Offset Rear Lower Links
Metal Tech Rear Upper Links
ICON Rear Adjustable Track Bar
Removed rear sway bar
5th Gen 4Runner front brakes StopTech true BIG Brake Kit for 400$ (DIY)
GEARS
Nitro 4.56 Gears (front and rear)
ARB RD121 Front Air locker
Nitro Rear Chromoly Axle Shafts
ARMOR
Expedition One Kodiak Front Bumper
Expedition One Trail Series Rear Bumper with Smooth Motion Tire Carrier
Expedition One Trail Series Rocker Guards
Man-A-Fre skid plates 4+plus
RCI Metalworks Front Skid Plate (required modification to fit with Exp1 front bumper, but now I don't need to remove it to change the oil filter ?)
Ricochet Control Arm Guards
BudBuilt Diff Skid
FJ ToyMan Rear Shock Skids
Polar Bear Tail Light Guards
All-Pro Lower Link Mount Skids
ENGINE/UNDER THE HOOD
TRD Cold Air Intake
Odyssey 31M-PC2150ST Battery
HKB Electronics Alternator Voltage Output Booster MK1
130 amp 4Runner Alternator
Big 3 Cable Upgrade
2 Gallon Expedition One Washer Fluid Reservoir
Hayden Automotive 3680 Rapid-Cool Thin-Line Electric Pusher Fan
Hayden Automotive 677 Rapid-Cool Plate and Fin Transmission Cooler
Hayden Automotive 1010 Power Steering Oil Cooler
Fumoto F103S Qwikvalve
Toyota 15620-31060 Oil Filter Cap
Painless Wiring Dual Battery System
- Optima D34/78 YellowTop Battery
- Bluetorch Fabworks Optima Battery Box
Copper Bussmann Series 15400 Rear-fed Fuse & Relay Module (RFRM)
Wolo Big Bad Max Horn
Painless Wiring Remote Disconnect Kit (30204) to isolate winch
Sprint Booster (not under the hood, but does enhance acceleration)
LIGHTS
Lifetime LED H4/9003 LED Headlights
Hella Optilux 4" LED Fog Light Kit w/ Fog light switch conversion FJ-FOGSW
Vision X 4.7" 25-W LED Light Cannon Driving Lights
Rigid Industries SR2 10" 52.4-W Driving LED Light Bar
Rigid Industries E 40" 220-W Combo LED Light Bar on DeMello light-bar mount
Oslamp Curved 50" 288-W Combo LED Light Bar on Trailworx A-pillar mounts
Vision X 3.7" Optimus Black Round 10-W Narrow LED Spot Lights on DB Customz Cowl Light Brackets
Diode Dynamics 921 XP50 Cool White LED reverse lights
Rigid Industries SR-M Flood LED reverse lights mounted on roof rack
PIAA 5190 510 SMR Series Xtreme White SMR Fog Lamp reverse lights mounted in rear bumper
Putco Pure LED Third Brake Light
DreamConceptz LED smoke lens tail lights
DreamConceptz LED front bumper indicator lights
Interior LED lights (cheap from Amazon)
Amber LED mirror lights (with diffuser removed)
LiteSPOT LED Rock Lights (8)
RECOVERY
Superwinch EPi9.0S Series Master Winch
Pull Pal
Hi-Lift Jack
Hi-Lift Off-Road Kit
ARB Premium Recovery Kit
4 x MaxTrax
ARB X-Jack Exhaust Jack
Deadman Earth Anchor
Shovel & Axe
STORAGE
Springtail Solutions HD Rear Door, Side & Straddle MPAC Racks & MOLLE packs
Department of the Interior Overhead Console
Garvin Industries Axe & Shovel mounts
Expedition One Hi-Lift mount
Raingler FJXN Rooftop Loadbearer Net
Raingler FJBN Barrier Net
Adventure Trailers NATO-style Jerry Can Holder mounted on Tire Carrier
MaxTrax mounts on roof rack
COMMUNICATIONS
Cobra 75 WX ST 40-channel CB radio
Bandi Antenna Mount
Firestik Firefly 3ft Flexible Antenna
Cobra 75 WXST and Bandi Mount Install
Kenwood TM-D710GA 144/440MHz FM Dual Band Radio
Diamond K550KM Roof Rack Mount
Comet SBB-1 and Diamond NR770HB Antennas (for on-trail and off-trail, respectively)
Qualcomm GSP-1600 Satellite Phone (just in case)
STEREO/ELECTRONICS
Kenwood Excelon DNX996XR
Metra Axxess ASWC Universal Steering Wheel Control Interface
Dual port USB charger/audio socket (connected to DNX996XR)
Blue Sea Systems 1045 Fast Charge Dual USB Charger Socket Mount - on back of center console
Kenwood CMOS-310 front view camera
Clarion XC1410 Compact 4-channel car amplifier
Bazooka TMS-SA-FJ Rear Speaker upgrade
Polk Audio DB351 3.5" 2-way dash speakers
Alpine SPR-60 Type-R 6-3/4" 2-way door speakers
Kicker 10CVT651 6.75" 1 Ohm Thin Profile Subwoofers mounted using Wicked C.A.S. Rear Speaker PODS
Kicker 12PX2001 200W x 1 Compact Car Amplifier
SNAN 300W DC 12V to AC 110V Power Inverter with Dual AC Outlet and 4.8A Dual USB Charging Port
ScanGaugeII mounted above mirror using BlendMount Kit BSG-1000
Hypertech in-line speedometer calibrator module
Garmin Nüvi 500 3.5-Inch Portable GPS Navigator - with topographic trail maps
Redarc Tow-Pro Elite trailer brake controller
GoPoint BT1 Wireless Auto Diagnostic Scan Tool
OBDII Splitter Y Cable, J1962M to 2-J1962F
MODS
Scuba mod
Body mount chop
BAMufflers High Tuck Tail Pipe
Bushwacker Pocket Style Fender Flares
RK Sport Ram Air Extractor Hood
OTHER
Trail Teams Edition Black Grill
Trail Teams Edition Black Mirrors
Trail Toys EZView mirrors
OEM Black Door Handles
3M Gel Wrist Rests as door armrest pads
Husky liners: front, rear, cargo
Clazzio Leather Seat Covers
Metra Install Bay 5-Position Seat Heaters
Champion Seat Systems 2-Position Seat Ventilation System
Tuffy Security Console
Autobahn Kraftwerks Sports Pedals
Lightinsight lense (to see overhead traffic lights without straining my neck)
Ellis Precision "Stealth" AT shift knobs and e-brake cover
WeatherTech Side Window Deflectors (loose fit on drivers side :mecry: : fixed with double-sided tape :))
Blue Sea Systems 5025 ST Blade Fuse Block (Ato 6 Circuit)
Blue Sea Systems 5026 ST Blade Fuse Block (Ato 12 Circuit)
ARB on-board 12V twin air compressor (CKMTA12) - mounted on Side MPAC Rack
ARB 1 gallon forged aluminum air tank
VDO Vision Black 2 1/16" 0-150 PSI Air Pressure gauge - mounted on driver's side vent panel
VDO Vision Black 2 1/16" 8-16V Voltmeter gauge for second battery - mounted on driver's side vent panel
Hopkins 47185 Multi-Tow Adapter
RAM X-Grip Phone Mount
RAM Windshield Mount for Garmin Nüvi 500
RAM Mount + Lifeproof Cradle Case for iPad mini
SF Giants 2012 World Series Champions License Plate Holder ?
Nice looking rig
Looks nice!
Thanks all. :cheers:
Discussion Starter #9
Recent Pics from Moab trip:
Discussion Starter #10
Here are some pics of my compressor install
Compressor
Switches: dual battery (on [charge mode]-off-on [start mode]), compressor (on-off), Pusher fan (on [thermostat controlled]-off-on [manual on]), back-up lights (on [reverse on]-off-on [manual on/tailgater blinding mode])
Gauges: second battery voltage and air pressure
oh sweet i love gauges then i know when something changes one thing i like about american trucks.. and digging the placement of those switches! :bigthumb:
Discussion Starter #12
Here are a couple of pics of my second battery and solenoid
Discussion Starter #13
And some pics of the Rigid Industries SR-M Flood reverse lights mounted on roof rack - these are plenty bright enough :rocker:
Nice pics of Moab trip and I like your Rigid lights! :cheers:
nice looking rig! hopefully i'll see you on a trail or sometime! good pics of the mud pit at HH
How do you like that compressor? Do you hook it up directly to tires to air up or do you have a tank that you fill? Is it pretty loud? I am considering getting one or getting a Power Tank but am currently on the fence.
Nice rig!
Discussion Starter #17
Nice rig!
The compressor is great. I have a small tank and filling up the tires is pretty fast. It does make some noise, but tolerable and not for long - it cuts out when it reached 150 PSI, and when you're filling the tires you're outside anyway.
4-Corners Moderator
Super awesome rig!!! Love the placement of the switches and gauges! Looks really clean and professional.
Discussion Starter #19
Discussion Starter #20
Replaced my K&N 63 air intake and Exp1 washer fluid bottle with TRD CAI and the new Exp1 higher volume washer fluid bottle.
Reactions: GammaBruiser
1 - 20 of 64 Posts
