1 - 2 of 2 Posts
LAMIN-X PROTECTIVE FILMS at SUPREMEPOWER FOR YOUR FJ CRUISER
-Looking to protect your investment?
-Want to have optimal lighting at all times?
-Tired of rock chips that can damage lights, and in time make lighting dim?
-Have roof or bumper lights that need extra protection too?
Then look no further, LAMIN-X Protective Films from SUPREMEPOWER is here to help! AND at Supreme discounts, its hard to say no. Order today, or give us a call to get your custom cut Lamin-x film for your Roof or Bumper lights!
CLICK >>[email protected]SUPREMEPOWER<< :clap:
Discussion Starter · #2 ·
-Lamin-x Film from SUPREMEPOWER-
"A simple application, yet very effective to protect your lights from rocks, chips and more-"
Lamin-x installation of the film takes less than 30 minutes to install!
Just need to clean the lenses off of any debris, oil, or gunk.
Lamin-x comes pre packed with installation instructions, and applicator squegee, FJ correct pt# TJ006 from Supreme-
PREP. JOB:
After cleaning headlights off with windex or rubbing alcohol- i then sprayed h20 onto the lens so i could affix the lamin-x film. Lamin-x recommends mixing the h20 with a little soap so you can center/slide the film easier.
Then hold by the tabs (later cut-off/removed), so you can center the film. Start from the middle, outwards with the squegee to take out all the bubbles/water. What you'll be left with is the excess tabs
Carefully, cut excess tabs (use a sharp razor or xacto blade).
Here is the final results-
passenger side
drivers side
Some applications may take a bit longer to dry due to various weather/temperature climates.
1 - 2 of 2 Posts
