1 - 20 of 31 Posts
So what do you guys have left to do ?
Things i have left to do
1) Finish cleaning all the Red sand out and off from my last Moab trip :mecry:
2) Install trans Cooler and Flush
3) get a tire deflater ***** . Done
4) figure out a spare Fuel solution :thinkerg: Maybe just a rotopax mounted to roof rack or spare tire ?
5) install new Oem windshield wiper blades that i have .
Admin
Take my rear tires off and adjust the emergency brake... needs to be a bit more effective.
MOAB SUPERSTAR
Install front pads & rotors, 5 tire rotation, swap rear diff fluid, detailing, DRL OFF switch. All the big stuff is done. Now just need to stop weekend wheelin trips so I don’t break anything :rofl:
Need to retune my CB, break in the new tires, and finish organizing my gear. All of my major stuff is done.
Go to Total Wine and buy some tequila for @Orion_FJ.
1. Tire rotation
2. Install new front bumper w/ lights and rock rails
3. Install Rotopax Base Mount w/ Fuel & Water Rotopax
4. Recheck CB tuning
5. First aid kit
6. Mount Fire Ext
7. Pack up an entire family
Reactions: ZerosFJ
Discussion Starter #9
1. Tire rotation
5. First aid kit
6. Mount Fire Ext
How are you mounting the Rotopax ?
Does anyone know if the route from Moab to Ouray is effected by the fire?
You can check here.
https://www.fs.usda.gov/detail/gmug/alerts-notices/?cid=stelprdb5421602
I think you are largely traveling through Uncompahgre National Forest while traveling from Ouray to Moab (at least through the Colorado portion of that trip).
p.s. edit....not even going through Uncompahgre NF if you take the paved route from Ouray to Moab. If that is the route you are taking just check Colorado road conditions here:
http://www.cotrip.org/home.htm
My comment relates to the back way from Ouray to Moab via Rimrocker Trail etc.
Admin
You can check here.
Road Conditions, Speeds, Travel Times, Traffic Cameras, Live Streaming Traffic Cameras, Road Closures and Road Work Information provided by Intelligent Transportation Systems (ITS) a branch of Colorado Department of Transportation
Hmmmmm.... Rimrocker trail sounds more fun than pavement :thinkerg:
I'll have to do some research!
start here. It's really Montrose to Moab....but close enough
http://montrosecounty.maps.arcgis.com/apps/MapJournal/index.html?appid=294f88f09b3c4002b4e9cd87511fe3b1
Here's the Colorado PDF:
http://rimrockertrail.org/wp-content/uploads/2018/05/GeoRefRimrockerTrailMapMontrose.pdf
Heres the Utah PDF:
http://rimrockertrail.org/wp-content/uploads/2018/05/GeoRefRimrockerTrailMapUtah.pdf
Basically goes up and over the Uncompahgre Plateau/NF and ventures through part of the Manti LaSal NF to get to Moab. The longer, slower more scenic way to get there.
I am a dirt biker and have done some dirt biking down there. This route is mentioned on a lot of dual sport or adventure biker forums.
Thank you!
Reactions: Winterpeg
Discussion Starter #19
I would bet a shinny penny there will be some sort of red bits somehow on your FJ friends. Iconic bumper .lol
Reactions: Iconic_
MOAB SUPERSTAR
-Oil change for my FJ. I think that's pretty much it..
-Help my brother finish his swing-out bumper. Fabricate and install an Iconic_ fab bumper on a friend's FJ.
-Pack up and roll out!
>:D:browsmiley::browsmiley:
1 - 20 of 31 Posts
