1 - 9 of 9 Posts
We have had very heavy rain in NY all of June. I have been finding puddles on the drivers side floor. When inspecting, I find water dripping from the fuse box. Does anyone have any exprience/fixes?
Just for giggles...Check your headliner...Is it wet also? (sometimes hard to see if not looking due to the grey color)
Have you had the windshield replaced?
Have you run any wiring through the firewall and into the fusebox?
Do have a roof rack? or has someone added a sunroof?
Search the forums. I recall other owners citing leaks in the around the driver's door and the cause was a problem with the rubber weather stripping. It was a defect known to Toyota and repaired under warranty.
See the thread Soaking wet driver's seat belt.
^^^ Yep that and the roof rack seals are know culprits...
how did you fix the leak? i have it on my FJ... and i have no idea...
Most likely its the seams on the roof panel pull the 1st roof rack cover and molding and reseal the seam with silicone,I had a leak I chased and this YT video led me to finding it .
FJ Cruiser ROOF LEAK Repair
1 - 9 of 9 Posts
