1 - 9 of 9 Posts
Hi everyone, I have 2012 fj cruiser with stock suspension but my car is leaning to the left more than normal know that the fuel tank and the battery is on the driver side but its obivious that something is wrong because i tried to put a rear coil spacer on the driver side but its still leaning. My car problem is similar to this car .
What other possibilities can their be other than the suspension that it causes the car to lean to the left?
there is a bit of a "natural" driver's side lean, so I'm assuming its more significant ... did it happen all at once, or over time ... I'm no expert, but could be a weak rear spring ...
:thinkerg:
Might be your driveway, I know depending where I park sometimes it is worse than others.
I have a left leaning FJ with 6" Fabtech lift. Does anyone know of any aftermarket rear springs that would work for this situation and maybe correct the lean without having to compensate with front coilover adjustment? The coilovers and rear shocks are relatively new.
Admin
Put a fridge and dual battery on the right side.....
Sent from my SM-G950W using Tapatalk
The TTUE suspension with Bilstein 6112 fixes that by setting the driver's side one notch higher than the passenger side. I have that suspension and no lean here.
The 10mm spacer in the rear fixed mine, if it's worse than that my guess is you've got a spring failing.
Has it had a rough life?
1 - 9 of 9 Posts
