1 - 4 of 4 Posts
I installed LEDs. I had to remove these rubber caps. Now the caps dont fit with my LEDs. How critical are these caps and should I modify them to fit?
1122349
assuming your LEDs have a longer cable than the typical bulb, what I did with mine was slide them into the grommets first, and then I popped the inverted part of The grommet outward and just screwed it in place and it sealed up around the bulb
When I installed LED’s on my FJ, I was able to remove the bracket from the bulb, that fit into the headlight housing. I clipped the bracket from the bulb into the headlight housing first, then I put the rubber boot on and then slid the bulb into the boot and bracket.
1 - 4 of 4 Posts
