1 - 5 of 5 Posts
Stupid question but how do I replace the bulbs in the stock map light housing? I don't see where the lens comes off...does the entire assembly come out?
i made a small hook with a paperclip. press the light cover to make a gap in the middle and insert hook. pull down.
lens pops off. the clips are the hinges in the middle of the housing. when you press the lens to turn on the light, the lens swivels out and up. this spreads the gap in the middle allowing you to insert the hook more easily. center the hook and pull firmly. hinge clips will pop out.
1 - 5 of 5 Posts
