1 - 7 of 7 Posts
I wanted a lift as well and decided to go with the Ready Lift leveling kit. It is a spacer that goes on top of the front struts and does not require any compression of the spring to install. It brings the front of the rig up almost
2.5" and gives the truck a much beefier look. I also installed BFG AT KO tires in a 265 size. This way I really did not affect my gas mileage or ride. This will give you more clearance as well as the look you are after. Check out - ReadyLIFT.com. or pm me for more info.
Go For Quality Rather Then Price
Cuz You Can Have Problems Later Down The Road
The lift you are looking at is a front spacer that requires the front springs to be compressesd. The rear springs are probably not worth anything, do a google search on spring tech and see what you come up with.
Alright I hear alot about ToyTec lifts so I checked out the website. I was looking at the 3 in. lift with:
3" Front Lift Spacers-CNC Machined From T-6 6061 Aluminum,
6 longer top plate spacer studs,
2" Rear Lift "Medium load" coil springs (OME 895)
Does anybody have this setup? Please feel free to give info good or bad. Thanks!
David
1 - 7 of 7 Posts
