1 - 5 of 5 Posts
Just received my stage 1 icon lift with a light racing uca. Only problem is the directions with the uca were for rear links not the uca. Think i found all the info i need except for the torque spec for the large nut that holds the ball joint to the uca. Of course light racing and everyone else is closed. Does anyone know the torque required???? THANKS FOR THE HELP!!!
I'm 90% sure it's 120 ft-lbs, though it may only be 100. 100 ft-lbs should definitely work until Tuesday when you can call them and ask, as long as you don't take it off road.
Very off you got the wrong directions, since I don't think LR makes any rear suspension parts...
120-125 ft lbs IIRC :)
Thanks for the info. At least now i don't have to wait until tuesday to get started with the front. I put the rear lift in yesterday and look like i should be going to the drag strip.
1 - 5 of 5 Posts
