1 - 7 of 7 Posts
I've had my eye's on these things for a few years. I hope to buy one around 15K. I hear they are very reliable, but at what mileage point is it not worth buying for that price point? What are some common issues you have with your truck?
Two and a half years ago I bought a 2010 with 120,000 on it. It has 195,000 on it now. I had to spend $400 to get a rear axle seal replaced. Other than that it’s oil and tires. I found one at a dealer. I am the second owner. The first owner had all the maintenance done at the same dealer. She never missed an oil change. I’m hoping to get to 300,000. I spent $16,500, so a little more than you want to, but you could maybe find that same 2010 now for $15K.
be sure to read this:
If you were going to buy a 2007-2008 today what common things would you check out before purchase besides the rear diff noises?
Second owner of a 2013 that I purchased about 2 months ago with 201k miles. Had it checked over before purchasing and was given a thumbs up. Mechanic was shocked at how tight and clean it was.
Maintenance record. I would want to make sure they have kept up on fluid changes including transmission, transfer case, and front and rear differentials. Would also inspect frame/suspension closely for rust. Most differential failures would have occurred by now. Listen for any rear/front differential whine that changes when accelerating, or coasting.
I would also look for any [email protected] wiring and aftermarket add ons. Look for poor suspension lifts (e.g. spacer lifts) or improper work. Worn suspension, unevenly worn tires, etc. When I buy used, the closer I can get it to OEM configuration the better. This advice pretty much applies to any used vehicle that you buy. Avoid shoddy repairs and work from previous owner.
1 - 7 of 7 Posts
