1 - 11 of 11 Posts
This is weird,
I've got a loud scraping/rubbing noise from the front left wheel area, then all my dashlights light up (abs trac ect..) and it goes away. I replaced all the brake pads hopeing that would solve it, but no good. Any ideas out there?
Thank you
Has its been wet were you live? it could be that the pads are just wet. When I drive a car out of the carwash i work at they a wierd noise when braking and the cars jolt
sounds like the thin dust shield is bent and rubbing. take the tire off and try to spin the rotor and bend it back by hand if so. those things are flimsy and just putting the tire on can knock it out of wack/
Ok, Update.
It's my Left Front Wheel Bearing, got parts on order and will change out tomorrow. there was enuf Slop that the dust cover was being rubbed and Abs sensor also being rubbed. i'm just hopeing the abs senser is going to be salvageable.
1 - 11 of 11 Posts
