Alight- got an interesting one for you guys. '07 TRD, manual trans, 180k miles. About a week ago, I noticed that when I first start going, I get a REALLY loud thumping noise coming from the left rear and can feel it- it almost feels like I have a flat. Thump frequency seems to go with tire speed, but not engine. It thumps whether I'm in a gear or in neutral, clutch in or out. Then, after driving for a few minutes, it seems to disappear altogether. When I park for a while and then go, it happens again.
Tires look fine, wheels not bent. Thought maybe rear diff, but why the heck would it only happen the first few minutes?
That's EXACTLY what it sounds and feels like, but pressure is good. I'm running 33" BFG ATs on the stock TRD wheels. Tires have maybe 15k miles on them- no noticeable treadwear at all.
This sounds exactly like some version of flat-spotting or temporary tire distortion that gets corrected after the first few dozen tire revolutions, or the first few degrees of tire temperature increase.
Questions:
1. Does this occur EVERY time the vehicle is started, or only after sitting overnight?
2. Are you absolutely certain that you have isolated the thumping to the left-rear tire, or could there be multiple tires involved?
3. Is the vehicle parked indoors, or outside?
4. Has there been any recent change in weather conditions (reduction of night-time temperatures)?
5. What type of surface has the vehicle parked on when the thumping is noticed?
4. Are there any irregularities on the surface that the vehicle is parked on (potholes, gaps, seams or steps in concrete, etc.) that could deform the contact area on one or more tires?
Questions:
Seems to be only after it sits a while. Happens when I leave the house in the morning and when I drive home from work
Not absolutely certain. Definitely coming from rear. When I stick my head out the window, sounds like left rear.
Outdoors at night sometimes on dirt, sometimes on driveway. During the day, open parking garage
Some, but not drastic.
See above
Sometimes, but it seems to happen the same whether I park on dirt or perfectly smooth concrete
One thing I should clarify. I feel the thumping, but sound is more of a ping- definitely sounds like there’s metal involved. Feels and sounds like someone is sticking a metal pry bar into the rim while it’s moving.
Thanks again for the help!
Have you swapped the tires rear to front to see if the thump "moves"
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.7K members
Since 2005
