1 - 6 of 6 Posts
I just installed a new set of headlights all together and one of the low beams doesn't work after install. I plugged them in before the install and both worked fine I thought. Tried the previous two bulbs and neither worked on low beam. Figured 3 different bulbs couldn't be wrong. Any suggestions before replacing the wiring harness?
If you have absolutely no idea why the headlights are not turning on, why would the first thing you consider be "replacing the wiring harness"??
A few minutes looking at the lighting system schematic, and then a few minutes probing with a multimeter will show you exactly what's wrong, and it's almost certainly NOT a defective wiring harness.
Did you check the fuse? There are separate fuses for left and right, high and low. Then a multimeter and/or test light as stated above.
Sounds like you dont know if you have a good bulb or not. What was the condition before you did anything? Were the bulbs good ?
Turns out it was the fuse. Didn’t realize they were separate until I did some more looking around. Originally wasn’t sure if I had a wire come loose or something like that.
1 - 6 of 6 Posts
