Lucrum Tire Carrier Group Buy
10609 Views 98 Replies 30 Participants Last post by  Lucrum
Group Buy Over. Thanks!
1 - 20 of 99 Posts
june 11th.. i think i might have enough by then! *crosses fingers*
Looks awesome! Is this only for plate bumpers? (Have metaltech tube bumper)
wow awesome package you worked up there Chris!
lights/fuel/lights/fuel/lights/fuel/lights/fuel.....Damn it chris, You're killin' me over here......:bigthumb:
HAHAH I mentioned you today matter of fact. Our MT bumper needs to be modified to work with this system. I'll keep you updated as I get mine done, should be chopped by around next week. the sides wrap around too far for the swivels to fit. Still should retain it's badness.
PERFECT!
June 11 = Pay Day!
My wife will never miss it....lol.
Double ha! Yeah Mike mentioned that you had one. We will have to see how his turns out. Will require some cutting and welding to make the bumper strong enough to hold the carrier but its do able, however it is not something we will be able to do a kit for other than to offer the extra spindles and raw fab parts to take to a custom shop to have the work done.
Also updated the first post forgot to list the accessory rails.
Hey Chris are you using the final version or do you still have the prototype mounted up??
If you want to get rid of the prototype, i may be interested just to save a buck :)
Looks great Lucrum, i wish i had the funds to add this awesome set-up.
thanks prototype already has a good home. BTW thanks for all of your guys support
Will these ship in June?
Also, has there been any thought to have a package deal with the most common or sought after accessories for a single price? I was not sure if some items had to be ordered for others to work (like, can you have the Jerry Can lock without the cargo carrier setup). Speaking of the cargo carrier, is that sized to fit anything in particular, maybe a cooler?
Thanks for the nice product and all the info, I look forward to having one.
bump:)
A package would be sweet. From the diagram it does look like we'll need to purchase the accessory rail in order to have cargo carrier, jerry can lock, or hi-lift. Is this the case? Also, will there be height adjustment capability on the accessory rail as previously discussed?
As gsgmac mentioned, I'd like to know what items much be requiste in order for other modules to work. For instance, I'd like to get the Antenna Mount (passenger side), but does that require I purchase the Axe/Shovel mount too? Or, conversely, if I get the Axe/Shove mount only, does it include both legs, one of which appears to be the HAM/Axe/Shovel mount?
Looks great Chris! Don't think I can get in at this time, maybe next year. :)
Drool Drool Drool!!! Damn it man! I love it.
A BIG X2!
I have to buy super basic, so i'd like to know what i need now to get EVERYTHING later :D
It looks like the jerry can lock and cargo rack requires the accessory rails. Are the rails included with them or do the rails have to be ordered along with the lock and rack?
Yes they will ship in June should be 3-4 weeks after the Group Buy closes so depends a bit on the group buy but as long as we stay on schedule should be ok. At this point we are not doing any packages because it is still so new we are not totally sure what the most purchased items will be. You do bring up a good point though that to use any of the accessories that go on the jerry can side of the carrier you do need to buy the accessory rails to add them. Also you DON'T need the cargo rack to use the jerry can lock, etc. The only dependent accessory is the accessory rails. The cargo Carrier is 14 inches wide by 20 inches long, you can fit a couple small coolers sideways or anything you want with a net. All in all you should not go over 50 pounds with what you put in it.
A BIG X2!
The accessory rails come pre-punched with holes for the accessories so you can line up the accessories every few inches or so and adjust them where you would like.
See above
Everything is "a la carte" so you can build it the way you want it. The accessory rails are $45.99 for the group buy.
1 - 20 of 99 Posts
