61 - 80 of 80 Posts
Discussion Starter #61
Finished the plumbing and pressure tested the system.
Now just need to install the electronic drain valve (water purge for tank), and fabricate the skids.
Also installed a 2.5lb Halguard extinguisher in front of the passenger rear seat, very easy to reach from the drivers seat with a seatbelt still on.
Discussion Starter #62
Joined NAC for a ride in NH this weekend and had a blast. Added a little trail damage, broke the aluminum front bumper, and put the skids to work. Definitely need to start switching things over to steel for the kind of terrain we mostly see up here.
Discussion Starter #64
Great idea on the location of fire extinguisher! Looks like you found some good wheeling in NH - what’s the NAC?
NH is great for wheeling, literally hundreds of class VI roads out there, some can be pretty challenging.
NAC is Northeast Adventure Company, a local group that hosts organized trail runs and camping events. Great group of guys.
Discussion Starter #68
My Icon's were long overdue for a rebuild with over 40k miles on them, but lack of sparetime/downtime kept preventing me from getting around to it. Finally I just went ahead and ordered another set of the same 2.5" Ext travel w/ CDCV for the front to swap in. The yarrived today, so I'll be swapping the new ones on in the next few days, as well as chopping up the Icon UCA's to add heim joint with a higher caster offset so I can run 5 or 6 degrees of caster, as well as a little more negative camber, and also rid myself of the eccentric bolts that never want to stay in place and run larger through bolts.
If anybody is looking for a used set of Icons to rebuild (that come w/ new 650lb springs, and upper/lower mount bearings and clips)... I can help.
Gratuitous new coilovers in a box pic:
Discussion Starter #75
Been a while... I plan to sort through pics of the various trips I've been on the last few months, including another 4 day trip last month back to Canada to explore more of the Bay of Fundy.
Recently cut up my Icon UCA's to replace those shitty poly bushings with sealed rod ends and boots, and also to give myself more caster and camber adjustment options.
1117872
1117873
1117874
Also, finally received the Goose Gear platform I ordered late summer, unfortunately it arrived the day we got back from Canada, so I have not been able to get out and actually test out how much more comfortable is to sleep in there now. But the extra storage is great so far.
Just a couple pics from Canada:
1117875
1117876
1117877
MOAB SUPERSTAR
Rokmen UCAs use heim joints which I thought was brilliant, except NE corrosion would’ve killed them. Those boots look nice and stout - bet they were no fun gettting on! Let us know about your enhanced adjustability once you get them installed 😀
Discussion Starter #79
High quality sealed Heims are key, these are also SS.
Castration pliers FTW, only took 5 seconds each. The boots fit water tight, but I also snuck a needle fitting up under them and filled them with green grease when I installed them.
Been running them for over a month and they have been great, was able to get back to -.5deg camber up front and 4.5 caster on a 3.5" lift. Before I was maxed out adjustment wise at +.3 camber up front, and with the increased caster it was destroying my tires when turning.
Discussion Starter #80
Day trip with the NAC crew the other weekend.
Got a full sized tree wedged up above the rear axle, exhaust and driveshaft. Pic below is after 2/3rds of it was already removed, took a nice mud bath getting that one out. Luckily no major lines were taken out.
61 - 80 of 80 Posts
