1 - 5 of 5 Posts
I used the search function and found many interesting thing about maintaining our FJ's. Almost an hour later of looking at these threads i forgot what i had searched for. Sorry but i want to post my questions here.
When changing the plugs do you really have to remove the air cleaner assembly? What is the use of the 10" extension when removing the plugs? Are the plugs really that deep down in the head?
Is the 6 point 15/16 the best socket for the fill plug on the rear diff? Thanks.
yes all the below things you ask... it is really not that hard to do at all. on the driverside you will need to remove the support bar or loosen it so you can get your socket in the back sparkplug.. otherwise Youcandoit...
1 - 5 of 5 Posts
