1 - 5 of 5 Posts
I recently purchased the MAF upper and lower control arms (rear). I know the lower is pretty much a brainless install but with the uppers being "adjustable" and the effect on drive angle etc does anyone have any experience and pointers on the installation?
Any assistance would be appreciated.
Have you tried using "search" there are a ton of threads on this already. I've been researching front UCAs and can assure you this subject have been covered in the past.
Sure thing. I did a complete write-up on the Man-A-Fre links actually. Check it out below.
A Series of Tubes: Upgrading FJ Cruiser Control Arms
As far as adjustability goes, just make sure that the bolt holes on the MAF upper links line up exactly with your original stock link mounting holes. Easiest way to do that is to set them both down on the ground, side by side, and slide your mounting bolts through both old and new link at the same time. That way you're sure to match.
Cheers,
Jeff
BOW...thank you, exactly what I needed to know.
1 - 5 of 5 Posts
