I am still out of the country, but will be back in a matter of weeks now. No promises but let me see if I can get some West African Beer home. Besides the map light and the scanguage is there anything else I need?
I am still out of the country, but will be back in a matter of weeks now. No promises but let me see if I can get some West African Beer home. Besides the map light and the scanguage is there anything else I need?I'm sure we can work something out. I'm rather fond of good beer. :lol:
Im trying help you for all the help you've given me....See post 396 and you will see how far back mine is, since you are doing a reverse mount because of the scanguage dont know for sure if this will help or not, but in that location there was no obstructions --- post 396: http://www.fjcruiserforums.com/foru.../83363-unique-mods-post-your-pix-here-40.htmlQuestions:
How far away from the map light should this be placed? wesayso, I think you said yours is 5.250" from the mirror. iCruiser is much closer. Is it just personal preference? Any problems being close vs farther away?
Is iCruiser just "compression-ed" mounted? Wouldn't the map light "give" a bit when you push on it because there is nothing behind it? Or is the headliner that stiff?
In iCruiser diagram, does the wooden mount go front to back or side to side. Do all 4 screw go into the mount or only the front two or back two? Sorry, but the diagram is confusing to me.I don't know what the view point is.
Make a template. Double check everything. Tape template in position, being sure it is oriented correctly. Use a fine tip marker to trace around the template. If you do all this correctly, cutting it out is the easiest part. As Stig pointed out, use a new razor.Thanks Steve. Nice install of the console. :bigthumb: I'm still shaky about cutting that headliner. :lol:
Forgot to show you this earlier, http://www.fjcruiserforums.com/forums/interior-exterior-visual-tech/108827-sound-proofing-fj.htmlThanks Steve. Nice install of the console. :bigthumb: I'm still shaky about cutting that headliner. :lol:
Would like to see some pics of that.:bump: because this is still the coolest Scangauge install ever! :bigthumb:
...and to let you guys know I chickened out and went with the 3 Intercepter gauges in the dash cluster option instead. I just couldn't cut my headliner. :lol:
BTW, if anyone is interested in doing this mod, my 'kit' is available in the 4Sell section.
Post pics when you have time.For anyone interested, the map lamp from a Honda Accord without the sunroof works nicely in the FJ. You will have to remove the basic FJ lamp and bracket and enlarge the hole to match the Accord map lamp. I used a flat sheet of metal and a flat bar to fabricate a mounting plate and brackets. It turned out to be very nice. Feel free to ask for details and pictures.
