I don't remember what it is called. I've had it for years and most of the print has rubbed off the tubes. Sorry. There are a lot of things out there that will work. I used to have this stuff that most auto parts stores have on their counters. It would work too.Wes, what's the name of the adhesive you're using, and where can you pick it up? I need to start brainstorming about how to mount it. I'm limited on powertools.
I'm thinking about starting this bad boy this weekend... I'm sure the girlfriend will love that, haha
Nah, cutting the headliner was one of the easiest parts. You just have to make an accurate template, tape in place, mark the cut line, and cut with a utility knife.This mod is a must do, but cutting the headliner scares the crap out of me. I know I'd screw it up.
I have a question about this. How did you wire this? I purchased one of this consoles (only it was from an acura.. in the pictures it LOOKS exactly the same...) and I'm having trouble imagining getting my soldering iron down in there for 3 connections. Are the pins you're connecting to a fair ways down below the top of the plastic? None of that wire shown came with the console, did it?OK, I finally got took some pics of the back of the console for those of you who asked for them.
This shows the wires soldered to the pins where the Honda wiring was attached.
If anyone still has questions about this mod, I'll be happy to help.
I used a thin tip soldering iron and didn't have a problem soldering in the hole.I have a question about this. How did you wire this? I purchased one of this consoles (only it was from an acura.. in the pictures it LOOKS exactly the same...) and I'm having trouble imagining getting my soldering iron down in there for 3 connections. Are the pins you're connecting to a fair ways down below the top of the plastic? None of that wire shown came with the console, did it?
I don't care about mounting my scanguage there. But I'd to have this console. I got one with homelink for my garage door.
Thanks!
you could use one of this, and then 'plug' it in?I have a question about this. How did you wire this? I purchased one of this consoles (only it was from an acura.. in the pictures it LOOKS exactly the same...) and I'm having trouble imagining getting my soldering iron down in there for 3 connections. Are the pins you're connecting to a fair ways down below the top of the plastic? None of that wire shown came with the console, did it?
Thanks!
I was looking at the console with the Homelink system. With the Scanguage installed, the Homelink antennae would technically be facing backward. Would this setup still work? or can the antenna be redirected?I got one with homelink for my garage door.
I doubt it matters. It's just your standard garage door opener. I can use my regular one half way down the street in my FJ.I was looking at the console with the Homelink system. With the Scanguage installed, the Homelink antennae would technically be facing backward. Would this setup still work? or can the antenna be redirected?
Just wondering.
T
Oh, I wonder if I can melt a drop of solder onto the terminal post first, and then stick the wire in there and melt the solder already in place.I used a thin tip soldering iron and didn't have a problem soldering in the hole.
BINGO! That is exactly how you should do it. Now go get em.Oh, I wonder if I can melt a drop of solder onto the terminal post first, and then stick the wire in there and melt the solder already in place.
If not doing it this way, does it take 3 hands?
Ah, see, this is why I plan my mods 3 months ahead of time - it takes me that long to stumble upon the necessary techniques.BINGO! That is exactly how you should do it. Now go get em.
wesayso Very nice install, I'm inspired!I was looking at the console with the Homelink system. T
i got one like thiswesayso Very nice install, I'm inspired!
Now could someone be nice enough to please post a link to the console with the Homelink system?
Thank you...
