1 - 7 of 7 Posts
Can those of you running 285/70R 17 , no lift on a stock FJ measure from the ground up through the center of the wheel to the bottom of the front fender flare. Im over 37””
1128002
What are you actually trying to figure out.
Sent from my SM-N960U1 using Tapatalk
If I have a lift on the New to me FJ or is it stock, suspension with 33’s. So in essence , Id like to know for those guys running 285/70r 17 with NO lift, what is their height measured as I showed.
Ok. Most of the time a better measurement would be center of wheel hub to bottom of fender. I did run 285s without a lift when I first bought mine. Now I have a 3in lift from toytec. I do remember my center hub to bottom of fender being around 20in before the lift something like that. But that's also dependent on what year the fj is. If it's a 2wd or 4wd. Not all fjs sit at the same height. From what I have seen. Right now I'm running 40in for your measurement. The first picture is before my lift and second 2 are after my lift. But looking at your pictures I would say you dont have a lift. If 18in from the ground is your center hub. That would find your center hub distance at 19.5. And that's right on par with stock ride height.
Here is my passenger side shock and spring, its a 2007 4x4 part time.
1128023
1128024
1128025
1 - 7 of 7 Posts
