I live not far from there in the Willamette Valley. I don't even know of any mechanics that I'd trust near me. I usually do most of my own work for that reason. You should read here and learn some of the most basic maintenance chores. This forum is a gold mine of information.
As for the shudder, how many miles on your rig? A transmission fluid drain and fill, or 2, may be needed since the shudder is a classic symptom of old ATF. But at high mileage, well over 100,000 miles, might complicate things. You may even find most shops will balk at either performing a full flush, or a couple of drain and fills (preferred if your FJ has a lot of miles). However, many here have done a couple of drain and fills on high mileage transmissions and have had good success solving the shudder and having no shifting issues.
