I really don't have much use for the inclinometer in the FJ's multi-information display. Plus, it distracts me bobbing around all over the place as I drive. I've decided to yank it in favor of a digital air pressure gauge for my (yet to be installed) on board air setup, which will include one or two 200 PSI compressors from Helix Suspension.
I decided on the AZ220K gauge by Air Zenith:
The AZ220K is rated to 220 PSI, and is available with a light or dark face. I chose dark as I thought it would look more at home in the dash pod. As a bonus, it offers the option of reading battery voltage for the first minute after power-up. The gauge can be had for about $75, delivered, and comes with the sensor. Hook up is easy: a DC wire and a ground wire and two wires to the sensor.
Digital Air Gauge (Black)
What follows will be a pic by pic account of how I modified the FJ's pod and then installed the air gauge, though, admittedly, after getting about half way into it, appears to be much simpler than I would have imagined, and it would appear to be totally reversible.
I may go back and add removal pics later, but for now I'll start with a freshly removed MID pod. And I just realized I neglected to take a few other pics, which I'll try to remember to fill in when I put it all back together.
1. Remove the Multi-Information Display, AKA dash pod. (pics later)
2. Remove the white plastic cover directly on top of the pod's electronics. There are two small phillips screws that need to be removed, and then two plastic tabs that must be depressed. The cover will then lift off. (pics later)
3. Remove the bezel from the gauge pod. To do so, you must release a total of six plastic snap latches, three on the top and three on the bottom. (pics later)
4. Remove the white plastic inner bracket from the pod. There are three small phillips screws that need to be removed. There is a connector integrated in the white plastic bracket that will need to disengage from its mating connector, you you'll have to apply a bit of pressure to the back side of the white bracket, right behind the thermometer LCD panel.
5. Remove the three small phillips screws from the back of the inclinometer.
6. Pop the inclinometer out of the white bracket.
7. Remove the inclinometer lens from the bezel. This can be done very easily with a sharp-pointed soldering iron. (Don't grind or scrape them off, we're going to try to re-use them to hold the air gauge lens in place.) Notice the four plastic blobs on the back of the lens. These were once plastic nibs that were melted down to hold the lens in place. One at a time, insert the soldering iron tip into the black plastic blob while applying pressure to the front side of the lens. The lens should pop right off the plastic blob. After doing all four the lens is free.
That's all we can do before we hack into the shiny new air pressure gauge. I'll post more pics shortly.
-Matt
-Matt
