1 - 1 of 1 Posts
Hello all,
Recently I purchased a RIGID Industries 50" curved light bar for my 2012 FJ. At the time of purchase I was not aware that this bar uses TWO mounting points stacked vertically. I spoke with Rigid and they said they went with the stacked double mount points b/c the back of the light is heavy and they didn't want the light to have a tendency to rotate backwards over time. Fair enough. My issue is I can't seem to locate any FJ brackets that fit this double hole configuration. I had purchased a RESZ Fabrication set of brackets that I thought would do the job but these only have one hole. Had the light bar mount points been horizontally laid out I could have just drilled into the bracket creating a second hole but since they are vertical I can't use them. If I'm out of luck I can have a friend try to use the existing RESZ brackets and fabricate a vertical tab to drill into. Any help would be greatly appreciated.
1 - 1 of 1 Posts
