21 - 30 of 30 Posts
Discussion Starter #22
Nice looking ride . Here comes the stupid question . Exposed wheels are bad in some way . Or its just the look your referring to
4-Corners Moderator
I have a similar setup as you. I have 35s on a 3" lift. Before 35s I was running 33s. It isn't the lift that will make 33s look small, it is those Bushwacker fender flares! Because of how far they stick out, smaller, less wide tires get swallowed by the fender flares and then look small. On factory wheels I had to get 12.5" wide tires and 1.25" wheel spacers to compensate for the extra width of the Bushwacker fender flares.
Here are 305/70R16 tires (essentially a 33x12.50R16) with 1.25" wheel spacers on a 3" spacer lift with Bushwacker fender flares.
1139508
And here is a 3" lift with 285/75R16 tires with 1.25" wheel spacers and the Bushwacker fender flares
1139509
Versus having 315/70R17 tires on the same setup
1139510
Running without flares too is always an option
1139511
You don't want tires too small with Bushwacker flares or else it looks like this
1139512
I think what he's talking about is that the stock rubber fender flares hang down about an inch into the wheel wells. Your Bushwackers simply go from the edge of the metal fender out. So the fender opening on your truck will be roughly 1" larger all the way around then an FJ like mine. I think mine looks great on 33" tires. But with the Bushwackers, it'd look a little like it skipped leg day.
Discussion Starter #26 (Edited)
I'm reconsidering going a bit smaller due to mpg concerns..maybe 305's and use 1.25 spacer like FJX2000 did in that pic above .Im assuming the apacers help the tires look like they fit better?
Discussion Starter #29
Nitto ridge grapplers weight almost 69lbs @ 305 70 r17
Duratracs weight 61lbs @ 315 70 r17 . Rotational weight affects mpg more than size so prob going with duratrac s
21 - 30 of 30 Posts
