1 - 5 of 5 Posts
I just put in 3" toytec lift now i wants some tires!!! I want some 33" how wide can i go with out doing a body mount chop
Well, if you get the OEM steelies, then you should be able to fit 285/70r17s on there with the body mount chop.:cheers:
If you get deep tread depth MTs, or some ATs you will likely rub at full lock with 33's, especially under compression. All-seasons, however, probably won't due to their shallow tread depth. Typically, the narrower the tire, the less rub.
Did you ever find out what will work? I have the same question and have searched
several time using the search forum, but have not found an answer.
1 - 5 of 5 Posts
