Hi all, just joined the forum and have gotten good info here in the past My auto mechanics knowledge is limited and I need some help. I have an early '07' that had a bearing go bad in the rear differential. The shop I took it to replaced all the bearings but said the pinion gear was OK. The problem I'm having which may or may not be a problem is that I have a gear winding sound when I have the accelerator down and it stops when releasing the accelerator. I also get a gear winding down sound when coming to a stop. I brought it back to the shop and they just replaced the fluid and said it should solve the problem. I thought this didn't make much since at the time and sure enough I have the same noise. This isn't a very loud noise but loud enough it makes me wonder if something wasn't put back right and is annoying. Can some of you mechanics on here tell me what the problem might be and if it's something I should pursue further with the shop or if it's probably nothing to worry about. Thanks Ron
