1 - 20 of 87 Posts
4-Corners Moderator
It has come to my attention that an update was needed, so here is the NEW Complete Roof Rack Comparison Thread! Hope this includes a lot more useful and clear info than the old thread to make your decision making easier when it comes to choosing the best roof rack option for you! And for the purposes of this thread I wont include basic roof bars like those offered from Thule, Rhino-Rack, or others that aren't true roof racks. Comment in the thread to share your thoughts on roof racks, post pictures of your set-up, tell others about other roof rack options and details, or let me know if I missed something!
And as requested, here is a link to the OLD Roof Rack Comparison Thread since it contains lots of useful info: Complete Roof Rack Comparison
Type of Roof Rack Guide:
Full – Replaces entire roof rack and extends most of the length of the FJ’s roof.
Half - Replaces entire roof rack but is a shorter model that may only extend around half the length of the roof, usually the rear half.
Drop-In – This design fits inside the factory roof rack and mounts to the factory roof rack.
AL Offroad Products
Type: Full Roof Racks
Price: $950
Build: high-strength aluminum-alloy, with matching brackets and stainless steel hardware in order to be rust free
Finish: The OG model sports Unfinished logos with stainless steel hardware while the Onyx Edition has Black logos with black stainless steel hardware
Light Mounts: Optional; Can get the roof rack with the standard front wind fairing or the optional wind fairing designed for use with a 44" ExtremeLEDs light bar
Load Limit: 400 lbs. (dynamic) and 800 lbs. (static)
Roof Top Tent Compatible: Yes
Accessories: Awning brackets, roof antenna mounts, hook point mounts, etc. See website for details.
ARB
Type: Full or Half Roof Rack
Price: $522 - $1,085 (Fitting kit is also required $132 - $207)
Build: Steel or Alloy (40% Lighter)
Finish: Powder Coat Black
Light Mounts: No
Load Limit: 330 lbs
Roof Top Tent Compatible: Yes – when using Steel Touring Style Roof Rack
Accessories: Wind deflector for 44” wide models, Universal Awning Bracket, Mounting Kits
Notes: ARB has 3 main designs of roof racks. First is their standard roof rack (87” x 44”) which is offered in a steel version or aluminum alloy version for those looking to save weight, but the steel version can also come with a mesh flooring. Next is their short roof rack (52” x 44”) which is just like the standard one but only offered in steel and no mesh flooring. And finally is their Touring style roof rack (87” x 49”) with a basket area in the front and flat section on the rear ideal for ARB roof top tents. The cheaper of the 2 mounting kits required only works for the short roof rack while the more expensive one is for all other roof rack mounting applications.
___
BajaRack
Type: Full or Drop-In Roof Racks
Price: $595 - $1,295
Build: Steel Tubing with Aluminum Wind Deflector
Finish: Black Powder Coat
Light Mounts: No, unless light bar accessory is purchased or Utility (flat) Rack with SPY Light System
Load Limit: 300 lbs (Driving) to 600 lbs (Static)
Roof Top Tent Compatible: Yes, both the flat Utility racks and the Expedition Rack (20" front basket and rear flat section) are compatible, not the basket style racks
Accessories: Fuel Can Holder, Hi-Lift Jack Mounts, Awning Mounts, Axe & Shovel Mounts, Solar Panel Mount, Maxtrax Mount, Tire Mount, Tent Plates, Water Can Holder, Yakima and Thule Accessory Mounts, Light Bar for 48” wide Racks to fit 7” or 10” round lights
Notes: BajaRack offers a drop-in basket design that works with OEM roof racks. They also offer Standard Basket racks with or without mesh flooring, Flat Utility racks in a small (51”) or medium (55”) width variation (used to be a large version but they stopped offering it due to its excessive width), a Flat Utility rack with their Spy Light System (has a small motor on it so driver can control a LED light bar that can lower behind the wind deflector or raise up above the wind deflector to shine forward), or their Expedition Rack for roof top tents as the rear section is flat to accommodate a tent and there is a small basket area up front for gear/equipment.
__
Ecotechne
Price: $850
Build: CNC plasma-cut and brake-formed steel, about 0.100” thick
Finish: Powder-coat black
Light Mounts: Yes, for LED bar in front (maybe 40")
Load Limit: 150 kg (330 lbs)
Roof Top Tent Compatible: ???
Accessories: Rear Ladder, and they produce FJ Cruiser front and rear bumpers.
Notes: Not much information out there. And website model shows the older model, pictured is the new model.
__
Eezi-Awn (Equipt Expedition Outfitters)
Price: $1,110 - $1,385
Build: High-grade aluminum, 60 lbs, Low-Profile Platform with 1-3/8" H, 5" Wide Slats, Running Front to Back, 5-1/8" Between Slats
Light Mounts: No
Load Limit: ???
Accessories: Compatible with your existing Thule or Yakima sports bar mounts for bikes, kayaks, etc. With a modular system to accommodate shovels, axes, jerry cans, and more.
Notes: Multiple full roof racks available in multiple sizes.
__
Expedition One
Price: $1,259.99
Build: all-aluminum light-weight construction, Flat load bar rail system
Light Mounts: Optional front fascia light bar cutout (fits up to a 40" led light bar)
Load Limit: Dynamic load capacity: 250lbs, Static load capacity: 500lbs
Roof Top Tent Compatible: Roof Top Tent Load Bar System (Coming Soon)
Accessories: Expedition One Accessory mounting options coming soon
Notes: Flexible mounting points along the internal railings
__
Front Runner
Price: $1,112
Build: Aluminum and Stainless Steel, 77.3” Long, 77 lbs
Finish: Black epoxy powder-coat
Light Mounts: No
Load Limit: 660 lbs (evenly dispersed)
Roof Top Tent Compatible: Yes, Expedition Rail Kit offered for full perimeter of rack to make a basket rack or for only the front or back to allow section of rack for roof top tent and other area for storage
Accessories: Expedition Rail Kit, 1255mm Slats, Hi-Lift Jack Bracket, Double Jerry Can Holder, 10” LED Flood Light w/ Bracket, Water Tank w/ Mounting System
Notes: Front Runner offers their SLIMLINE II ROOF RACK KIT for the FJ. Lots of accessories including slats to fill in the gaps and make a completely flat surface for the roof rack as well as the Expedition Rail Kit to create a basket roof rack design.
_
Garvin Wilderness Products
Type: Full and Drop-In Roof Racks
Price: $580 - $1016
Build: ???
Finish: Powdercoated
Light Mounts: No
Load Limit: 200 lbs for Adventure Racks (Drop-In); ??? for Expedition Rack (Full Roof Rack)
Roof Top Tent Compatible: No
Accessories: Hi-Lift Jack Mount, Ax & Shovel Mount
Notes: Garvin Wilderness offers 2 types of roof racks. First is their full roof rack, the Expedition Rack, Long Version, which is 48"W by 90"L and has 4"H sides. It also contours to the roof towards the rear so isn’t flat the entire length of the rack. Then they offer Adventure Racks which are drop-ins designed to mount to the factory roof rack. There are 2 versions of the Adventure Rack, first is the standard version which is 35.25"L by 36"L x 5"H and fits towards the front of the OEM roof rack. Then there is the XL version which is 35.25"W by 66'L by 4"H and fills in the whole OEM roof rack area. Garvin also has racks available for the rear cargo area and above the rear tire. Rock sliders are also available.
____
Gobi
Price: $1,495
Build: 1″ heavy gauge tubing, mesh flooring, integrated or removable cross braces optional (allow compatibility with Yakima or Thule accessories or for roof top tent mounting)
Finish: Black powder coated with an anti-rust undercoat
Light Mounts: Yes - for 4 individual LED lights or a 40” LED bar depending on roof rack version
Load Limit: 300 lbs (Driving) and 600 lbs (Static)
Accessories: Comes with Wind Deflector that can be removed for LED lights, rear ladders (3 different designs: drivers side w/ rear tire, drivers sider w/o rear tire, passenger side), ax/shovel attachment, adjustable cross bar, ARB/Tepui awning attachments, mini wind deflectors, tie down system, universal tire mount, tool boxes (standard or stealth)
Notes: Gobi offers 2 styles of roof rack, the Stealth and the Ranger, all come with mounting hardware and wind deflector. The Stealth only extends 6.5” above the roof and can be purchased in 2 variations. One Stealth variation allows for 4 small LEDs to me mounted on the front while the other allows for a 40” LED bar. The Ranger extends 8.5”above the roof and also has 2 variations, both built to fit 4 individual lights but one comes with a tire rack. Free ladder and shipping with any rack if in the Lower 48 States.
____
PrinSu Design
Price: $900
Build: Aluminum wind deflector, side rails, and crossbars
Finish: Side Rails - Raw Aluminum, Textured black powdercoat, or custom color powdercoat
Crossbars – Anodized clear or anodized black
Light Mounts: Optional, can get wind deflector cut out for 40" light bar
Load Limit: ???
Accessories: Lots of mounting hardware available that are compatible with the cross beams like RTT mounts, awning brackets, tie down rings, and more.
Notes: None
____
Rhino-Rack
Price: Backbone 3 Base Mounting System - $369; Roof Rack Options - $1,158 to $1,419
Build: Reinforced nylon and aluminium
Finish: Powdercoat?
Light Mounts: None
Load Limit: 265 lbs (Driving), 800 lbs (Static)
Accessories: Many options available on website.
Notes: Base Mounting System must be purchased regardless of rack. Multitude of rack options including basket-style, side-rail style, or flat racks most in different sizes. Rhino-Rack also offers options to add cross bars to the factory roof rack.
_
Sherpa Equipment Co.
Price: $719
Build: ¼” thick aircraft-grade aluminum side panels and stainless steel hardware
Finish: Raw Aluminum or Black Powder Coat (Note: Powder-coated orders will ship standard with black oxide stainless hardware. Raw aluminum will ship with standard stainless hardware.)
Light Mounts: Optional; The front fairing can be full size or half size to make room for a 40" ExtremeLEDs or Baja Designs LED light bar to be mounted (All rack systems ordered with a lightbar will receive their brackets and hardware.)
Load Limit: 400 lbs (dynamic) and 700 lbs (static)
Roof Top Tent Compatible: Yes; Secure your gear by bolting into one of the 9 extrusion crossbars or by strapping it directly to the side plates
Accessories: Handle light brackets, traction board mounts, awning mounts, hi-lift mounts, tent mounts, waterport mounts, etc. See website for more details.
____
Toyota
Type: Full Roof Rack (Half if Modified)
Price: $495
Build: Lightweight T-6061 Aluminum Material
Finish: black powdercoat
Light Mounts: No, unless OEM Air Dam is added
Load Limit: Drop-In: 150 lbs
Accessories: Additional Cross Braces, Front Air Dam w/ Aux Lights
Notes: Discontinued
____
upTOP Overland
Price: $850 for the Bravo rack; $1,400 for the Alpha rack
Build: Alpha series rack: 6062 1/4" aluminum, has a two layered side rail system that features both armorTEK and grooveTEK. The bars are a 1" x 2" 80/20 extruded aluminum. The mounting feet and front fairing are also both constructed with 6062 1/4" aluminum. Bravo rack build not explicitly stated, but it appears to be the same materials, except the side panels are a single piece with integrated armorTEK and grooveTEK vs having multiple separate pieces.
Finish: Bravo rack only comes finished in stealth black, but the Alpha rack comes in the main color of black but the side pieces (not sure on if it is the grooveTEK or armorTEK piece that comes colored) come in your color preference, and those colors are the same colors available for the FJ (Voodoo blue, Iceburg, Army Green, etc.)
Light Mounts: Can get the front fairing/wind deflector with a light bar cutout of your choice and both designs are ScenePOD compatible.
Load Limit: ???
Accessories: Grab handles, ScenePOD which utilizes Baja Designs Rock lights for lighting around the vehicle
Notes: Usable/loading area is 87" Long x 53" Wide, which website claims is the largest of any roof rack on the market. The website says "armorTEK is a slick little system that allows us to enhance the aesthetics of the rack on the truck while serving a functional purpose as well. The armorTEKs primary function is to hide and protect the wiring meant for rooftop accessories in a 1/2" channel between the armorTEK and grooveTEK.
grooveTEK is our multi-functional tie down system designed to specifically lock in the hook of Perfect Bungee Bungee Cords. The way the teeth kick back the hook is unable to slide down and out from the beating of the trail."
1136420
____
Viper 4x4 (VPR4X4)
Price: ???
Build: ???
Finish: ???
Light Mounts: ???
Load Limit: ???
Accessories: ???
Notes: Not much info is provided on website about this roof rack. Weighs 66.14 lbs and is 72 x 59 x 7 in.
___
Warrior Products
Type: Full, Half, and Drop-In Racks
Price: $489 - $821
Build: 11 gauge steel, outer round tube around the perimeter of the rack measures 1-1/4″ while the square crossbars measure 1″
Light Mounts: No - unless Pre-Runner light bar accessory is added, fits five 6.75″ round lights, but Warrior states "designed with open front for an ideal place to mount lights without taking up space on the rack"
Load Limit: Drop-In: 300 lbs, Half Rack: 700 lbs (though FJ roof may not handle this depending on weight distribution), Full Rack: 1000 lbs (though FJ roof may not handle this depending on weight distribution)
Roof Top Tent Compatible: Yes, for full and possibly half racks.
Accessories: Front Air Dam for full rack, low profile or top-mounted hi-lift jack mount, shovel & ax bracket, spare tire kit (drill or no-drill options), 2 or 3 awning bracket options
Notes: Warrior Products' full roof rack measures 89.5″ Long, 51-1/4″ wide, and 5″ high with a weight of 90 lbs. The half rack is 57-1/2″ Long, 51-1/4″ wide, and 5″ high with a weight of 82 lbs. And the drop-in cargo basket which includes mounting system to sit inside OEM rack is 51 inches long , 35 1/2 inches wide, & 5 inches tall. Many optional accessories available.
fka BLACK HAWK
Awesome! Can't wait to see the updated front and rear bumper comparisons! I love my Warrior Products Full length flat rack!!
Thanks for updating this. But I do have one concern and that is that the All-Pro Roof rack basically has top billing and I am not even convinced they make one. You say it can be custom ordered and it is not on their website. I see no evidence they have delivered one since 2014. See here:
http://www.fjcruiserforums.com/foru...roads-original-fj-roofrack-redesigned-73.html
The demand was certainly there at one time for these racks and they look great, but do you have confirmation both from All Pro and from anyone who has bought/custom ordered one in the last year and had it delivered timely.
I think All Pro has good stuff....I am just VERY skeptical that the FJ rack can even be ordered and delivered.
I Have a V-8!! Moderator
Alphabetical listings.
Yeah...i get that....but still because of alphabetical order, they get top billing. Same reason there are so many service companies with AA AAA AAAA in their name..at least from the old "yellow pages" days. It seems like an OK way to order the listing of racks (alphabetical), but my real concern is that by sheer virtue of their name they get 'top' billing and I don't think the rack actually exists. I will stand down if someone can point me to recent deliveries of these phantom racks. And, trust me I have nothing against All Pro. I just cant believe the amount of demand for something that basically just disappeared from the market. I have been on the FJ forum since 2009 and in my mind the "we'll have a rack out soon for you" has become a running joke for the old-timers on the forum.
I certainly haven't searched for every thread, so I am definitely open to the possibility that I am just not up to date on their current offerings and will happily delete or remove my comments in this thread if they actually exist and can be purchased/delivered.
4-Corners Moderator
The front and rear bumper threads are updated, pm me if there are specific details you know need to changed.
Yeah it is just a matter of alphabetical order with it showing up first. I will send a message to All-Pro though and see what I can find out about availability but when I talked to them at this last FJ Summit they say they don't list it on their site since it costs more to make a rack in than they get in return, but that you can still contact them and order one.
You can add Rhino Rack as well.
Good looking option.
I thought about it but it really isn't a true roof rack like those listed, just misc. cross brace options that a generic basket designs sit on.
4-Corners Moderator
Discussion Starter #9
Well I just heard back from All-Pro and it turns out they no long offer their FJ roof rack. I changed the info to not available in the comparison listing and I may keep the All-Pro listing there if folks aren't too opposed to it since it is such an iconic roof rack and that way people can see it.
Rhino Rack
Ahh that does look nice! See I couldn't find anything like that on their website, so do you have a link by chance? I'd happily add it to the listing. Their website search function was a little odd for me so I never saw something like that.
Done.
I think it is a new option for them.
They make vehicle specific for FJ, Landcruiser, Tacoma, Land Rover, Wrangler JK 2 and 4 door, and soon will offer 4runner according to the ad in the new Overland Journal.
Here us what the ad says.
Rhino-Rack Backbone
Stylish and Aerodynamic design
Minimize wind drag and noise on and off road
non corrosive materials will never rust or fade
strong and durable to allow maximum carrying capacity
massive dynamic and static load ratings
compatible with a large range of Rhino-Rack accessories
additional rail kits available
FJ Cruiser Static Load Rating up to 800 lbs
Here is the Backbone on Rhino Rack website
RFJB1 - Rhino-Rack Backbone 3 Base Mounting System - FJ Cruiser | Rhino-Rack
From there you can add a flat rack or one with side. A few different sizes.
Fit My Car | Rhino-Rack
Here is a link for instructions
http://vpm.cdn.rhinorack.com.au/Instructions/Parts/FittingApplications/RFJB1.pdf
Looking at the Rhino Rack website and their racks, I can't find anywhere where it states that the static load rating is 800 lbs. I do see their racks with load ratings beside them, and the highest rating is 265 lbs (I am assuming this is not static). Am I missing this info. on their website?
Like I tell my kids - Sometimes it's a huge burden... to be right 99.99% of the time....but it's a cross i have to bear. Love saying this especially when they doubt me!
I vote for removing it. You can post it under an "in memorium" thread or some such thing. And agree, it's a great looking rack but as rare a 71 Hemi Dodge Challenger convertible.
I saw it in their ad in overland journal
Just a minor thing to note, the Prinsu uses common 80/20 aluminum T slot cross bars, much like the Rhino rack and possibly Front Runner, so some of those accessories likely actually fit on the Prinsu attaching the same way.
https://8020.net
Reactions: Lonely Raven
4-Corners Moderator
Discussion Starter #19
Posting the All-Pro roof rack here instead of having it listed in the main comparison just for documentation.
All-Pro Offroad
Price: N/A
Build: Aluminum
Finish: Bare Aluminum
Light Mounts: Different metal plates for front and rear fascia available for mounting various LEDs, specifically Rigid Industries 40" single or double row bars on the front and 4 Dually LEDs on the rear
Load Limit: ???
Roof Top Tent Compatible: Yes, optional side plates available to fit roof top tents.
Accessories: Compatible with Thule and Yakima products
Notes: Not currently offered.
1 - 20 of 87 Posts
