Hopefully this is in the correct place, if not Mods please feel free to move.
I am contemplating moving to a new rear-end and have a few questions for those that are either smarter than I or have already done it. The Currie rock jock 60 is the obvious choice however there are a few more out there such as Diamond that could fit the bill as well.
My question centers around upgrading now using the stock 4-link and then changing down the road to a more 'extreme' setup with an SAS or a redesigned 4 link/3 link. Will 2 inches wider on each side ( total of 4 inches ) be enough when I want to go more extreme down the road?
I'm thinking, put the new rear-end on, regear to 4.56 or 4.88, continue to run my 295's or maybe move to a 35" tire and then later when the SAS comes still be able to use the 60. What kind of widths should I be looking for and would it be possible to remove the stock geometry bracketry without harming the housing?
Not sure why people are going high-pinion either, isn't there a loss of strength with that versus a traditional setup? I imagine there is a small ground clearance increase but is an inch worth the strength loss or am I overanalyzing here?
One more question: Is it possible to go full floater and still retain all the electronics? I understand the difference between semi-floater and full but don't understand why one is better than the other if that makes sense.
As always I have much to learn to feel free to tweak my questions as you all see fit. Thanks! :cheers:
