1 - 3 of 3 Posts
For those who are looking to purchase upper control arms, youve got to check out these new ROKMEN Pro-Series UCAs. Get back your proper alignment after your lift. Greatly improve your on road ride, and off-road performance and durability. The Rokmen Pro-Series front Upper Control Arms are designed for maximum adjustability and bind free articulation throughout the suspension cycle. Castor can be adjusted from 3-5 degrees and O-ring sealed Aluminum dust caps are included!
Part Number RM43013
2003+ Toyota 4Runner
2007+ Toyota FJ Cruiser
The most complete and bulletproof UCA kit available!
• Improved on-road handling for lifted vehicles
• Bind free articulation throughout entire suspension cycle
• Heavy Wall DOM Tubing
• Dual pass TIG Welded
• Precision bored after welding for perfect Uni-Ball fit
• FK Stainless Uni-Ball w/PTFE Liner
• FK Rod Ends at the frame w/PTFE Liners for maximum friction free articulation
• 17-4 Stainless Steel inserts & Uni-Ball Spacers
• Tons of adjustment options
• Machined ABS Mount
• Sand Blasted & Powder Coated
Free Included Weather Pack:
• O-ring sealed Aluminum dust caps, secured w/stainless bolts.
• Fully enclosed rod end weather boots
• Boot Installation Tool
• 2oz. of Tri-Flow dry lubricant w/PTFE
Easy Alignment / Adjustability:
• Castor can be adjusted from 3-5 degrees on lifted vehicles by varying the included rod end spacer sizes at the frame
• Additional fine tuning of castor, camber, and track width via rod end adjustability
#ROKMEN
#TotalAutoParts
#TotalAutomotivePerformance
Get yours here - RM43013
Thank you all for your continued orders and support! This brand is discounted during our Summer 2016 Sale - browse our site Total Automotive Performance and be sure to use the SUM16 promocode to save even more over T4R Forum Discounts for a limited time.
If we can be of any help please reach out to us at [email protected] or 702.979.1577
1 - 3 of 3 Posts
