1 - 8 of 8 Posts
hi, im trying to install a new Kenwood DPX308U in my 08 FJC, but i keep reading things on these forums where other double din head units wont fin in the FJ dash. so my question is, do i need brackets to fit my new stereo in the dash? and if so, what kind should i get? thanks
cool thanks alot. my fj is going to be so sick! i wanted to get a new head unit for the sound system im putting in. i am installing 2 15" subs in the back. im gona bump in my FJC!!! thanks again
You should try 3 10", same amount of cone but it will hit harder.
Thanks. I got the new head unit and the dash kit and they all fit perfectly. I noticed that there are three wire harnesses that connect to the stock radio. I was wondering if i needed an adaptor of some sort to make the connections.
You can go to Walmart and buy the cheap one that fits all Toyotas or buy for a few $ more the one with less wires that is only for the FJ
Scosche TA02BCB
or
Metra 70-1761
The 3rd or wider connector is for the audio steering control buttons (volume, channel and mode-audio source).
1 - 8 of 8 Posts
