1 - 20 of 23 Posts
I have a 2011 FJ manual transmission vehicle that I want to upgrade with the Method 105 Beadlocks, but I want to make sure these are ok for daily road use at fairly high speeds. How hard is it to maintain them?
I appreciate your feedback. Thank you!
I run them with 40" toyos on my '78 Hilux. They are quality wheels and I would not hesitate to run 75 mph on them. The last wheeling trip was in October and I finished the day with 4 lbs in the tires. Truck is sitting on the trailer with air still in the tires.
トヨタ Master
Just retorque them every 200 miles.
BTW, @Iconic Thorn's are not true bead locks I don't believe. Could be wrong. It happened one other time. LOL
I live in WY and drive 75 - 80 on paved roads with some fairly easy off roading in the mountains. Think I’ll be good with those rims?
Is it easy to retorque them?
Forum Beer Miester
Very easy to torque, I also keep a little stick of blue loctite in the FJ in case I have to break one down for repairs. I have to be honest, I haven’t torqued these things since I left for Utah last summer. 😂
Hey btw I told you the incorrect wheel, it is the MR105 bead-lock in a -38 mm backspace not the 305. Been a long day.
トヨタ Master
Yes, it is easy. I actually bought a tool online that was preset for my Walker Evans bead locks (15lb/in. If I remember correctly). I don't remember the company but you can put it on a 3/8 ratchet or small drill or impact to retorque. Where in Wyoming are you? I'm in Laramie.
So they are bead locks. I was wrong on that one. Did they actually turn when you retorqued them before Summit?
Discussion Starter #10
That’s the rim I want, but I often run 70 80 mph and don’t want any problems. Do you use a special tool to torque?
Discussion Starter #11
I’m in Powell — up near Cody.
Discussion Starter #17
Just a regular torque wrench you can get from any parts house, I keep one in my FJ. I run my FJ 100+ mph from time to time, no problem.
I think I’m going to go for it! Now I’m curious about the backspace. Do you have any pictures? Anything I need to consider? I reckon I’ll need some black lug nuts.
Forum Beer Miester
Get extended thread lug nuts you can find black ones on eBay, 12mm x 1.5 thread pitch. Depending on what backspace you get and the tire size you’ll need to perform a body mount chop and modify the inner fender slightly.
Discussion Starter #19
My tires aren’t that big 285 70 17
If I get -38 mm back space do you think I’ll need those modifications? If so, I may not do any back space.
トヨタ Master
Um, unless you're running spacers, all Toyotas are 12X1.25 pitch. :cool:
1 - 20 of 23 Posts
