1 - 4 of 4 Posts
Bought 2 sets of these 1 for the Tundra & 1 for the FJ, Since we traded the FJ in i only want 1 set for the Tundra. These are brand new in the box never taken out.
$175 O.B.O + SOLD
May sell both sets for $350
PM or email mannyrodriguez1976(At)yah**(DoT)com
These can be coverted to run HID Lightforce has a factory upgrade that can be purchased
Amazon.com: HID RMDL Single Lamp Upgrade Kit 5000K 12Volt 35Watt - Fits RMDL 140,170,240: Automotive
Taken from Lightforce's website
It may be small, but the 140 LANCE™ can be a wise choice! If you need high performance in a compact package, this is the answer. Off-road comp vehicles often install these as fog, winch, crawling or reversing lights with dispersion filters. Remember with LIGHTFORCE you can customise the colour and beam pattern to driving conditions! Make no mistake, even our smallest light is off-road race ready!
• Compact performance for any size or vehicle type
• 12V 75 watt Xenophot® 4000 hour bulb (maximum wattage) 24V halogen available
• LIGHT OUTPUT | 110 000 candela | 1 lux @ 450 m
• Lightweight polycarbonate, glass filled nylon composite construction
• Gore-tex ®breather (IP57/67/68/IP69K) to protect against moisture/contaminant ingress
• Ideal as a fog light (with opt. YELLOW / AMBER filter) or off-road reversing light
• Ideal for use as a winch light with a DISPERSION filter
• CLEAR SPOT clip-on polycarbonate filter supplied | Others available
• WEIGHT (single unit) 460g | 1lb .2oz
Is the wiring harness included with this kit?
1 - 4 of 4 Posts
