1 - 5 of 5 Posts
2007 fj cruiser 150,000 miles. My brakes are gone (les than 5%) emergency brake working, brake light on dash board on.
No leakes on brake lines, master cylinder full.
please help, vcs,abs etc lights on .
disconnected the battery to reset computer and didnot woked.
2007 FJC 4x4.
If they are gone maybe part of them broke off and took out a wheel sensor. Have you gotten in there and taken them apart to see yet?
Emergency brake will work anyway since it doesnt rely on the calipers, but a drum brake assembly within the rear rotors.
The only time my brake system went off is when the little vacuum pump took a dump. So with that said I think that would be a fuse you probably did not check.It does not look like your common everyday looking fuse.
It was the brake assembly pump (abs) if I hit it it stray working, brakes come back. I order the replacement. Thanks and I hope this helps anyone in the future.
1 - 5 of 5 Posts
