Yesterday I had the opportunity to install some brand new skid plates from Ricochet Offroad right here in Utah. Just figured I would mention a couple notes about the install process to help those doing future installs.
So the instructions are pretty good that they give you but one thing I am so glad I got before starting was a tap and die kit from Harbor Freight. It had the necessary M8 x 1.25 tap necessary to run through all the holes. Luckily all the holes on the frame that you use are the 8mm x 1.25, so you really dont NEED a whole kit, you could possibly get only the part you need from Amazon or something.
For me, since most of my bolt holes were super stripped or cross threaded, chasing out the frame threads was super important to the success of the install. And even then I had 3 that were too stripped to thread bolts into, including the two front-most welded frame nuts. Luckily the bolts provided ARE long enough that I could thread them through the frame and use a nut on the opposite side of the frame since the frame is narrow enough right there. I actually used the nuts originally from the gas tank skid since they have an incorporated washer design that works well for that application.
Speaking of the gas tank skid, just make sure you only undo the fuel tank ground strap at the front of the tank and then the 4 bolts that are on the bottom of the factory fuel tank skid. Do not undo the straps to the side of the tank that actually hold up the fuel tank... or else the fuel tank drops on you and the plug on top of the fuel tank comes undone. Don’t ask how I figured that out haha
The hardware comes in a bunch of different plastic bags with different numbers and letters that I imagine mean something but don’t really help you with the install. The one with the HD on it is probably front main skid plate. The one for me that had ExpOne on it was for the filler plate, then the others had letters like B, C, D and those were sort of in order of the skid plates as you go from front to back. You’ll figure it out one way or another. Haha.
Also, the instructions do not mention what to do if you have a filler plate for an aftermarket bumper, such as an Expedition One Bumper in my case. I was having trouble getting the holes to line up and I even went as far as loosening the bolts for the bumper so I could sort of shimmy the bumper around. It wasn’t until I called Brad at Ricochet the following day that I discovered you need to put the filler plate up IN the bumper vs trying to bolt it from the outside. After that it fit like a glove!
Here is a before and after of what I did. Silly me.
Also, there is a steel supporting crossmember that comes unfinished from Ricochet and needs to be prepped and painted in order to avoid rusting. I just got some paint+primer from the store and gave it a matte black finish. Just keep that in mind in case you open up all the boxes with the intent of installing it all at once but then realize some painting is required. Luckily I got some quick drying paint and I would paint a coat on and then work on the installation of some of the skid plates and then paint another coat and I just keep doing this until I got to the point where I had to install it. You start from the front skid plates and work your way back and if you are like me and are taking your time then you’ll have time to paint it as you work and let it dry if you don’t put it on too thick.
When it comes to the catalytic converter protector tubes that are removed but then reinstalled, you reinstall them with rock blocks and countersunk bolts that fit in between the flanges on the cat. converter protector tubes. I found that my flanges were a bit too tight for the blocks, if I had a bench grinder I would have taken off a little material on the sides of the blocks to make them fit just fine, but seeing as I didn't have that I took some vice-grip pliers and widened up the flanges by prying them outwards. It worked from what I could tell.
And finally, I installed the lower control arm skids last and found no problem installing it on the factory LCA. But one of my LCAs is actually a Moog LCA and one of the holes that a bolt is supposed to run through was ever so slightly too small. So you could either drill it out slightly to make it large enough or do what I did and run the 8mm x 1.25 tap through it and then thread the bolt though. It was simple and worked! So it is nice to know that even with non factory LCAs, the skids still work almost perfectly.
Well hopefully this helps someone in the future, I’m going to bed!
