1 - 2 of 2 Posts
Hello , I Wanted to put some stock switches on my fj to power the remote switch of a SUB and some L.E.D lamps,
I wanted to buy some stock switches , I found some CHEAP USED stock switches , But I'm confused about the wiring part , originly for the parking Sensor with a light the other is for RR-Diff Lock.
I figured out this with a multimeter
but
confusing because of this orange light config
thanks
thanks guys
The middle two are for on/off or momentary on depending on button type.
The two with the orange bulb is for back lighting. And the one with the single pole is the positive feed for the indicator. The GND feed will be shared from the backlight bulb.
Pop the switch apart and you'll see what I am talking about. There is a trace on the inside that leads to one of the other pins.
1 - 2 of 2 Posts
