1 - 20 of 29 Posts
Hi,... do you really need to buy this valiance with the cut out for a trailer hitch or are there trailer hitches for the FJ that sit under the rear bumper for towing light landscaper trailer? Thanks.
There are other options for aftermarket receiver hitches. I installed a Curt on my FJ. I like it very much. The receiver is below the level of the bumper and no bumper valence change is required to install it.
Just make sure you get the factory trailer wiring harness as that is much easier to install.
as said above, yes you can, but it all seems to cost the same either way you go. and removing the bumper is not that bad, it's the torque of the bolts when installing the receiver that gets scary.. 70lb/ft seems good the 80lb/ft is overkill for the thread pitch, but got all of them to 80.
It's not clear exactly what you are asking here ... the OEM Toyota hitch kit comes WITH a replacement valance with the clearance cutout for the hitch.
There are even two different versions of the hitch kit, the "standard" one with the silver valance, and the Trail Teams version with the black valance. Price is the same ...
Sold separately is the hitch wiring harness kit, which is the cleanest and safest way to add trailer wiring. It just plugs into existing (capped) connectors on the vehicle's wiring harness.
I think the OEM hitch is superior to aftermarket hitches on multiple fronts: much lighter weight, doesn't reduce rear approach angle, not as likely to get damaged when off-roading, etc.
You should try Hitchweb. They have a lot of options for FJ Cruisers. I'm sure they will have something for you. Here is the link if you wanted to have a look: Toyota FJ Cruiser
Hope this helps!
^^This ;)
I.m actually having my OEM hitch installed today. I think it is definitely the better option over the other hitches IMO :cheers:
etrailers.com
When I bought mine, it was on sale.
I think they have 3 different brands. Two of them are basically the same (I forgot which one I got)
Hardest part was removing the factory bolt for the tow hook. It was definitely cross threaded in there. One came out like butter, the other took some serious effort and a very long pipe attached to the breaker bar to get it completely out.
Discussion Starter #10
Thanks everyone... great info. My 2010 FJ has the silver solid valance and I want to switch out for the trail team valance with hitch notch insert... are there any step by step instructions for this? Or should I simply buy a new OEM bumper that has the valance with hitch notch already there?? From the above info, I have decided to go with OEM valance with hitch notch just not sure how hard it is to swap out one valance for the other. Truely appreciate all the help, this is my first FJ bought last May so I am just starting to improve what it didn't come with.
oem hitch kit comes with a valance silver or black your choice, its fairly easy after that instructions are included in it when you buy oem harness kit., and no you dont need to buy a new bumper
I don't mean to sound like a tightwad, but $90 for an 18" wire connecting the harness to the flat 4 seems excessive to me. Any aftermarket?
Except the harness kit is far more than "an 18" wire".
In addition to the cable, you get:
1. A sophisticated solid-state overcurrent protection module that plugs into the vehicle wiring harness under the dash in the driver's side footwell. This protects the FJ's wiring harness from any type of short-circuit in the trailer wiring.
2. A relay that plugs into the engine bay fuse block;
3. A pair of 15A fuses.
Yes it's expensive, but it's by far the cleanest and electrically "connect" way to connect the trailer wiring into the FJ's electrical system. All the aftermarket kits tap into the wiring system using the crude crimp connectors that cut through the insulation on the individual wires to the tail lamps. To me, there's absolutely no comparison.
See the OEM installation instructions here, which also shows all the individual parts contained in the hitch harness kit:
http://www.purefjcruiser.com/docs/fj-cruiser-trailer-wiring-harness.pdf
The OEM hitch looks wimpy as hell. I just replaced my Demello hitch that bolts to the Demello rear bumper with a drawtight 75461. The Demello couldn't handle a 3700lb trailer.
The OEM is a chunk of metal smaller than the Demello hitch. There is no way that OEM hitch lasts when dealing with loads close to the FJ's max. The drawtight 75461 is beefy and fits snug up to the fjS body.
.o2
The OEM hitch looks wimpy as hell. (snip)
Have you actually held the OEM hitch in your hands? Do you know what the thickness of the steel plate is that it's fabricated from?
Also, what exactly is your fear when you say "There's no way the OEM hitch lasts ..."?
Metal fatigue? Fractured mounting bolts? Something else?
Have you heard or seen any reports of any kind of structural failures with the OEM hitch?
Just trying to understand the nature of your concerns ...
The hitch kitch for the TT (i.e., PT228-35110) is now discontinued. For those of us who are not lucky to find it. It looks like we have to spend the extra money and get the black valance (i.e., PT228-35110-HC) separately.:crying
.o2
I too have concerns about the strength of the oem hitch. I love that it looks good, but need to insure its capability of towing 3-5000 lbs
Huh. I was under the impression that the hitch was not only tow-capable but usable as a recovery point. Not so?
And by hitch I mean the OEM hitch.
1 - 20 of 29 Posts
