Something is not correct, this should not be an issue. Pictures??I installed the lift yesterday and I think the only problem I have is that the bottom of the spring holders (where they sit in) on the shock in the front is touching the sway bar on both sides.... Any suggestions??
This is most likely the solution to your problem. Which way are those bumps on the spring cups pointed? I had mine pointed pretty much in the direction of the oil drain plug and never had any issues with rubbingThere should have been info about "properly clocking" the springs.... go back and read through that info. I'm pretty sure your springs were assembled with the clocking off. They will rub if not clocked properly.
